Welcome,
only a few parts are needed for the Sg circuit. They are as follows:
transistor-mjl21194 or 2n3055- mjl is best
diodes- 1n4007
resistors, 100 ohm 1/2 watt and 1k ohm potentiometer same wattage for multi strand coils use 470 as a base resistance
a single Ne 2 neon with or without the 4.7k inline resistor
a grain of wheat bulb (not needed for multi strand machines) available at most hobby stores, they are used in HO scale train sets for train headlights and running lights. get the smallest wattage you can find. this goes in the trigger circuit of bifilar coil machines only.
http://energyscienceforum.com/files/...0datasheet.pdf
