Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: Parts list for the schoolgirl circuit
    Bill,
    we did the 8 trans kit for symmetry and John's older SG's have 9 transistors on them, our boards are approved by John B. it really does not matter how many you use. you can order the 8 filar coil and kit, or a 7 filar coil and just have a spare transistor in case you blow one up as they are all matched with each kit. leave it out of the kit completely and hold on to it.
    we have everything in stock.
    Apr 2015
    South Africa
    12
    Thanks Tom,
    What is the difference between an 8 filar and the 7 filar that is used in the SG beginners kit? Does it produce more output? Would I need to add more magnets, or a bigger wheel?
    or would everything work normally with 21 magnets and an 8 filar coil?
    it has 1 more wire.... 8 power 1 trigger instead of 7 power 1 trigger. its the same wire gauge and length. output varies with tuning. I can run a 4 strand with more output than an 8 strand. wheel size number of magnets and magnet spacing are all factors. run the biggest wheel you can, with the magnets 3 to5 widths apart.
    and yes everything will work as designed with an 8 strand plus trigger. your input current draw will be a bit higher.
    imagine the SG circuit by itself, 1 transistor. now multiply them in parallel and you have a 8 strands machine. you can have 1, 2, 3, 4 or more coils, with varying number of strands and wire gauges. up to 80 or 100 transistors all doing the same thing. its all about what you are trying to do.
    Apr 2015
    South Africa
    12
    Excellent reply.
    excited to start my build, but want to source the basic things locally. Buying the entire Transistor kit, and a pre-wound coil will save a lot of time and energy. Probably more cost effective as well.
    @ All,
    1 SG......, REMAINING ALL SSGs for a Multi-coil rotary system how z that!!!
    once you get a hold on the multi-strand theory..Multi-coil system is at a flip of switch way!.. but guess what it just doesn't end there..what can be the next step??
    'Worm -hole' ......just kidding:..think think its all there in a pondering mind!!
    it could be a matter of two coils consisting multi-strand coils each to graduate to Multi-coil system... btw it need not be rotary either.. applicable to SS Multi-coil system.
