Results 11 to 20 of 22
Thread: Plexiglass rotor (for old 10 Coils Kit)
    I like your design. Did you make those rotors or have them fabricated? Would you share your design with those of us who would like to fabricate a plexiglass rotor for our 10-pole kits?
    Monty
    Montreal, Canada
    19
    Hi Monty,
    Send me a PM and i'll forward you the .dxf so that you can have it made locally. They'll generate the g-code from the file and get exactly what i have. I haven't completed the other changes yet, wider braces... will likely do so over the next few weeks.
    D./
    Hi D
    Your design looks great, if possible I would like a copy of the .dxf file also.
    Just wondering how your progressing, and Tom I'm also interested in your ply rotor, how is it going.Can someone tell me if the original kit circuit wiring diagram works with
    the super pole configuration or is there a better circuit available.
    Merry Christmas and a special to thanks to JB and all the moderators.
    Cheers,
    Flux
    @ All
    Now you 10 - Coiler kit owners are going to start cooking, just don't forget to post/share and keep the interests up. It’s an excellent built machine with almost everything in place and with this mod you could be looking at JB’s results or close.
    Theunis
    D's design replaces the kit 3/4" aluminum rotor and neo magnets with two 3/4" plexiglass rotors plus a 1/2" spacer for a total width of 2" - to march the length of ferrite magnets that are 2" x 1" x 1/2".
    You would be able to put two magnets facing each other for superpoles, or one or two of those magnets with N poles facing the coils.
    What is not designed yet is the replacement for the "U" shaped plexiglass spacers that bolt the two frame plates together. The opening in each U for the aluminum rotor is too narrow for a rotor with a total thickness of 2".
    Quote Originally Posted by Flux View Post
    Hi D
    Cheers,
    Flux
    I have not had any apple ply ones made yet, no one responded. my cnc guy can do wood or plexi. so if there is interest I can take D's DXF file and have a batch run. just need some interest and the file then I can send it to my guy and he can give us pricing. I don't have a 10 coil so I personally don't need them, but I am happy to do this for everyone.
    tom C
    Quote Originally Posted by Monty View Post
    Monty, you don't need the u shaped spacers. I took them out with this rotor and there are no problems. The rectangular block shaped spacers at the bottom are all you need.
    Montreal, Canada
    19
    John,
    I suspected those additional spacers were overkill, tks. for advice, wondering if it had anything to do do with the high RPM range Rick was contemplating running the 10 Coiler at... are you running your 10 coiler? results?
    D./
    Montreal, Canada
    19
    Flux,
    Sure, attached is the pdf. and the dxf output. Note i am using 3/4" material, trying to keep the cost in check. 2" material is double the cost.
    I haven't had much time to continue with the spacers yet, likely going to be next week. Also need to wind the coils with 18 gauge. Has anyone on the thread used the attraction method and tested results?
    D./
    Attached Files Attached Files
    Quote Originally Posted by 888spo View Post
    John,
    D./
    Hey D./,
    I'm running mine at around 600 RPM. I'm getting pretty good results at 12v front and back, although if I had better batteries the results would be much better.
    I have not run the 10 coiler in attraction mode - too difficult to re-wire, re-wind or flip magnets. I have however run my bike wheel super pole setup in attraction mode (re-wound the coil). The machine was definitely more efficient, but charging was slower in comparison to repulsion mode. Note that it was just a quick test and I did not spend a lot of time re-tuning or enough load cycles to conclusively say which mode is better or worse.
