Page 66 of 66 FirstFirst ... 1656646566
Results 651 to 656 of 656
Thread: How to Make a Bedini Crystal Battery
  1. #651
    BatteryForming_2008_04_25_16_16_47.wmv
    This video is on you tube, i find it very interesting, i would like to know how JB got the lead crystal material to grow on those plates, is it just a matter of putting current to them for a long time or is lots of charge/discharge cycles. The reason for asking is, this video inspired my son to make some homemade cells for a science fair project, he is now at 118 chg/dischg cycles and there does not seem to be any type of growth on the plates, they have turned colors just like in video.
    The cells have grown in the sense that they will do real work for the discharge part, just no visible change other than color.
    The lead plates he used are pictured in my previous post, made with the old waffle iron. His goal was to form them as lead acid and then convert to alum like JB did in video.
  2. #652
    Diego,
    the formula is proprietary and it is very toxic when wet, and when curing. I asked John about it last week and he said he is not going to make them, it is just too dangerous. He did one for proof of concept but is not going to make anymore.
    He probably started playing with mercury https://www.google.com/patents/US3333918
    My understanding of it all in laymans words is that we have reactive chemicals in non reactive metals .
    The Metals are technicaly reactive but protect themselves through electrochemical creation of crystal oxide layers ( of various metals) , these crystals made by John are what Kervran did in his experiments .
    For example Gold & Platinum in Sufuric acid , the reaction is blocked by a film of growing crystal oxide ( which i believe we accelerate by adding pusing power .. didnt read the science yet in detail)
    So what we get is that we have a galvanic reaction BUT it's happening in that crystaline layer with the potentials provided by the materials gold & platinum in sufuric acid case .
    With Sodium Carbonate you get the same with a multitude of metals . Karpens simplest battery is
    Sodium Carbonate with 2 different quality copper , carbon or other metals . Aluminium also has this reaction .
    Applying heat will change this naturally .
    I wanted to ask you if you could point me to the latest mix endorsed by John seen as it all went dead .
    Much appreciated
  3. #653
    Jul 2015
    North Texas, USA
    Homemade Lead Acid Batteries Complete Guide
    www.youtube.com/watch?v=C7gp3XjsH64
    The title says Lead Acid but the guy actually creates a Lead Crystal battery. He only uses Ammonium Sulfate and rain water.
    The key thing to watch for is that he reverses the polarity after each cycle to reduce the battery's resistance. This causes the battery to hold more amps and volts after each reverse cycle.
    One of his cells was shorted without his knowledge until the end of the video or his results would have been even better.
    I'm going to try reversing the polarity after each cycle in my next test.
    Roy
  4. #654
    1,513
    In this update video I’m showing where the energy is coming from with this type of system.
    John Bedini & Chuck Hupp.
    Hi Team,
    This is a reminiscence of what John showed us on a bigger scale and perhaps of an Associate iteration(G-Field like) of the same effect in his website, where a light bulb (Incandescent bulb) is seen running a Rotary Energizer and keeping itself powered all the time..
    The Patent 'Circuits and related methods of Charging a Battery' says that the Oscillator can be scaled up which means that one can have a scaled up version of the set up John showed us here and have a Practical Solar like Lighting for free!!!!!
    Gold bless his soul!!!!!
  5. #655
    1,513
    @ All,
    I have been testing this theory for months now, but I did not want to say anything until I was sure what was going on. The mix was very simple 50% Alum (Ammonium Aluminum Silicate) and 50% (Sodium Carbonate) in Chucks tests he has been working for several months at these little cells to see what was going on. You will always find Chuck measuring things. The Oscillators I have posted before on how to make them. It is important the exothermic reaction stops between the Alum and the Sodium Carbonate. Then the mix is watered down to make a liquid out of that and the plates are immersed in the mix that is liquid. A forming charge is applied and then the battery is drained and this is repeated until the oxides are formed. I used Sheet Zinc but other things can be used. This cell can be critical with the insulator material as it can form dendrites between the plates. The Oscillator is a SG circuit in forced condition. It is not my intention to sell anything the information has always been on the groups with the SG Energizer, but then who is listening to what I have said. I have covered this many times that the current is not wanted in my circuits. The negative effect or termed a negative resistor takes place in the cells chemical, same as a lead acid battery, Again I will point this out to you all,,,,Prigogine system: a many-particle system which is deliberately forced to exist far from thermodynamic equilibrium, and which exhibits negative entropy. Note that local curvature of vacuum spacetime places the local virtual state flux in nonequilibrium conditions, with the result that an observable energy "sink" or "source" can be produced.This can be seen in the cell temp going negative to ambient room temp.
    John wherever you are!!(in the Space -Time Continum) i have always been listening to you...I have always stood by what i said in my...Yes Knowledge hails from the past and its people..Future only holds the Arena of its realization!!! I miss you John..
  6. #656
    1,513
    Quote Originally Posted by jiant View Post
    A question for making the semiconductor copper. Can the oxide layer be achieved through electrolysis? So bascically, is there another a way to make the semiconductive copper other than heating it.
    Yes you can do it..but as JK said why do you want to eat the hard way when you can easily eat straight!! but there is a sense in doing it that way as well.. you can Electroytically do this which gives you a control on the thickness of the oxide layer..but what Electrolyte is the next question?
    Just my guess.. Molten salt Electrolysis with Anode Copper (that you want to coat)..Which salt ??...may be Sodium Peroxide?? still a guess.. the down side in this is that you still need to do heating (Sodium Peroxide Fuses at 675 C)
