Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
Thread: Question about DVD#39 Energy from the vacuum: The bioharmonic machine
    Hello all,
    In the movie John talks about the use of a spectrum analyzer and that the frequencies are very low.
    On the spectrum analyzer a range from 9Khz to 1,5Ghz is shown next to the type number.
    I have very little knowledge of a spectrum analyzer, can somebody help me further what those specs are related to?
    Odenton, Maryland
    129
    Quote Originally Posted by bruno View Post
    Hello all,
    I have the two DVD set Part 39 where John Bedini goes over the design of a Bio-harmonics Machine that John Cejka
    made and license out to farmers for their crops. The spectrum analyzer John had in the video was a Rigol DSA 815.
    The 9 kilo Hz. to 1.5 Giga Hz. is the frequency range of the Rigol DSA 815. Below are the features of this spectrum
    analyzer. The bolded text below was the way John Bedini was using his spectrum analyzer in the video to show the
    output transmission signals being produced by the machine out the antenna of the device.
    9 kHz to 1.5 GHz Frequency Range
    Typical -135 dBm Displayed Average Noise Level (DANL)
    -80 dBc/Hz @10 kHz offset Phase Noise
    Total Amplitude Uncertainty <1.5 dB
    100 Hz Minimum Resolution Bandwidth (RBW)
    A spectrum analyzer measures the magnitude of an input signal versus frequency within the full frequency range of the instrument.
    The primary use is to measure the power of the spectrum of known and unknown signals. The input signal that a spectrum analyzer m
    easures is electrical, however, spectral compositions of other signals, such as acoustic pressure waves and optical light waves, can be
    considered through the use of an appropriate transducer. Optical spectrum analyzers also exist, which use direct optical techniques such
    as a monochromator to make measurements.
    By analyzing the spectra of electrical signals, dominant frequency, power, distortion, harmonics, bandwidth, and other spectral components
    of a signal can be observed that are not easily detectable in time domain waveforms. These parameters are useful in the characterization of
    electronic devices, such as wireless transmitters.
    The display of a spectrum analyzer has frequency on the horizontal axis and the amplitude displayed on the vertical axis. To the casual observer,
    a spectrum analyzer looks like an oscilloscope and, in fact, some lab instruments can function either as an oscilloscope or a spectrum analyzer.
    -- James
    Hello James,
    Thank you very much for the explication, seems I need to save an buy myself such a device
    When I read about the oscilloscope that also could be used as spectrum analyzer, it came to my mind that maybe my scope has it also (will look at it this evening), but never used it until now. The scope offcourse will only go to 60Mhz, so for a better overall view the analyzer will be needed I think.
    Is there somebody who knows what the most important range is for the bio harmonics machine? (I mean above or beneath the 9 Khz)
    I want to share the title off a very good book concerning the subject of bio resonance:
    "In Resonance with Nature" from Hans Andeweg (ISBN: 9780863157059)
    There you can read that it is even possible without electric equipment to work with the morphic fields (Rupert Sheldrakes theory).
    The book is also available in dutch ISBN 90 215 3248 4.
    I watched the 2 DVD's #39 Bioharmonics machine and it is interesting to know how the thing works... John did not finished his talk about a semiconductor equivalent. Do you think that it is possible to build this machine with transistors ?
    Also, could it be possible to do this machine with transistors and the final stage with a vacuum tube ?
    I think so.
    Something to think, the machine use less than 30 Watts of power when running and how much energy do you think it would take to reproduce a tornado or big rain ?
    So where does the energy come from ?
    Take care all.
    I think we should not consurn about bad things like tornado even killing insects is for my opninion nothing that you should do with such a machine.
    If we know how to improve our crops and the enviroment that should be the goal.
    For example you take a dead bug for placing on the plate and the poison to kill it with and all those specific bugs are killed in that neigbourhood that you target (I know also the ground and tree leave are placed on the plate).
    This means that it's resonating on a complete species, so what if someone wants to destroy a bees nest and it goes wrong, all the bees in the neighbourhood are killed, so who gonna furtilise the crops?
    What if someones kid has come in touch with the leaf off the three and you don't know about, that kid could be poisened, if you take soil out of the garden,it isn't a clean room, you also walked there and left dna behind.
    So working or not I really think that we should only care about improvement and protection, don't think the battery will save you, because if those morfic fields exist the machine is like using a car to get somewhere, it's easier then on foot but sooner or later it's gonna be back on your frontdoor.
    I know that scientific proof is given that DNA from human interacts instantly even kilometers away if a person feels for example scared, so I'm pretty sure those morfic fields exist.
    This is my opninion and I'm not a specialist.
    This machine will kill you ...... do not build it. do not mess with the wheelworks of nature, not kidding here. I have had the honor of listening to the story of this machine from the horses mouth so to speak. unless you are willing to take the responsibility of the outcome of your actions...... if you build it wrong, nothing will happen, if you build it right, the unintended consequences of this machine are unimaginable.
    John said that this machine could help people, crops. But it must be use wisely knowing the consequences.
    If this machine is so dangerous so why put this information on dvd ?
    Anywhone with good skills in electronics could build this machine.
    Take care.
    Odenton, Maryland
    129
    Quote Originally Posted by Claude Champagne View Post
    I think so.
    Take care all.
    Hi Claude --
    I believe there are two reasons why John did not talk about a semiconductor equivalent.
    Reason 1 would be he did not want to be responsible for anyone getting hurt making this Bio-Harmonics
    device and Reason 2 would be since this device had at least 4 pentode amplifier circuits the closest
    equivalent would be a FETRON which does not have a suppressor grid equivalent circuit. The closest
    equivalent to a tube would be a FET. Transistors would not work quite the same. If you can find the tubes
    or for that matter a FETRON you could try to make the device. You may have to make your own FETRON
    in order to make this device. Then you would need at least a $1500.00 dollar spectrum analyzer to tune
    the device. The original schematic is on the Cejka Files DVD Part 20. This device appears to produce a
    wave front that used the earth's internal frequencies to transport its signal and to amplify it to a power
    beyond our control which is pretty scary. I would not recommend making the device.
    Thanks James for the input, you are right, about the Fetron. also there is the fact that transistors do not behave like tubes when they are in a circuit together, as the transistor is a discrete device, and a tube has all kinds of emf interaction with its neighbors. in truth I think it is the grids that cause the machine to work the way it does. I have only seen 2 of these my entire life, one is an original Cjeka machine, the other is the one on the DVD.
