Results 1 to 10 of 15
Thread: Transistor matching tester....help needed
    Angry Transistor matching tester....help needed
    I am constructing a Bedini SG and need help with the transistor tester I have constructed it and the meter needle does not budge no matter where I have the pot set or with the 27k resistor bypassed. I measured the voltage between the push button switch and the base of the transistor that will vary between 12 volts and 11.70 depending on the pot setting. I even tried reversing the transistor and the needle will move and the transistor will heat up. I can take a picture of what I have built.
    Ian
    Netherlands, The Hague
    112
    Ian can you make picture
    Here are a couple of pics
    am having trouble uploading pics will keep tying
    I have tried again to post a couple of pics but I get this red icon come up......,some kind of error message what other ways can I send you a pic
    Ian
    transistor tester 1.jpgtransistor tester 2.jpg Lets hope this the pics tried another method
    Ian
    Ian,
    Sorry I can't help with your transistor matching but how did you fix your picture upload? I am having the same problem on my post.
    Hi Bob,
    Yes it was a bit of a pain for as I have not been on forums for a while click in the immage icon that brings up a box with options, in the bottom right hand corner there is a "basic uploader" that is what I ended up using.
    Ian
    Testing upload pic
    *Edit*
    Many thanks Ian,,worked like a charm!
    I cant tell from you pics but it looks wrong to make things easier ..leave out meter and push button switch
    if you flipped the transistor it may be bad
    more pics will be helpful
    i dont see any diodes either
    if you are building a trans tester then disregard all i said
    i test trans with dmm https://www.youtube.com/watch?v=b0jCUsenNsY
    if you have a diagram of what you are building post it
