Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Tesla Node
    Hey Mike, only one way to find out
    I have not tried it with branch currents but you should be fine. I would try it with one charge battery first.
    This is tesla node charging taking all day.
    Mikey,
    If it takes that long to charge, something is wrong. Here are several possibilities that come to mind. Got your funnel ready?
    1. Your battery is too large
    2. Your battery is a piece of junk
    3. Your SG is not tuned
    4. Your Tesla Node is not tuned
    I'll give you the benefit of doubt and assume 1 & 2 &3 are ok. That leaves us with the Tesla node. What is a Tesla node? It's an inductance with a bridge across it. How could you possibly tune this? You can't change the bridge, so that leaves you with changing the inductance. You have tested 1 inductance value so far and found it does not work....so change it! If you don't have the electrical background to calculate the inductance what will you do? Yes, it can be done without math or a BS in EE, just change the number of turns on your coil or change the core. What will you do? Add 1 more turn? 10 more turns? 100 more turns? 1000 more turns? It doesn't have to be exact to see results, but you need to be in the ballpark.
    Tom C and I did this exact test 3 years ago. Our jaws dropped and when we hit the right inductance for our setup (no 2 setups are exactly the same), because the 1st charge battery was charging well, and the 2nd battery (across the Tesla node) shot up to 15 or 16V in seconds! (This was a discharged battery)
    Now that you have some suggestions what will you DO with it? Will you keep complaining when we don't spoon feed you?
    You need to FOCUS to learn. In the past couple weeks I've seen you work on the SG, the cap dump and now the Tesla node. Have you learned anything (or everything) from those? or did you just build them?
    Erik
    1,513
    Hi Bromikey,
    The 'Tesla One wire Theory' : A Single wire has TWO ends,The Wire 'Bulk' and the TWO ends of the Wire make it a THREE-NODE Scenario of Tesla Interaction,..does that give you any hint...??
    I think you are the ball player I saw with the huge Solid State coil on youtube. Totally expensive setup.
    Hi Mikey,
    I'm pretty sure you're thinking of someone else; The only machine I have shown publicly is the 42" aluminum SG at the 2011 conference.
    I'm glad to see you are making progress on the Tesla node.
    Even though I'm not much for posting, I do try to follow things on this forum when I'm not building and learning about this technology (SG's, comparators, four wave mixers, etc) for myself, I'm busy designing and testing boards for TeslagenX. (For those wondering....yes, we will have stuff to announce shortly....)
    Keep experimenting and learning!
    Erik
    Hi Mike,
    I believe he said 900 turns....
    I have been following your posts for a while and I truly appreciate your generous input. I was wondering if you will agree with me when I say that sometime we use "battery voltage" and "battery charge" as if they indicate the same thing. I re-read your last post "....charging goes way up and backs down after a time.." Do you mean voltage?
    Which leads me to my next question....Does the battery voltage go higher faster or do you still thing the battery is being charged faster.
    I guess the answer to all that will be to not only observe how fast the batteries are being charge but also to confirm by checking how fast/slow they discharge when hookup to a load.
    I am no genius, I would appreciate it if you tell me what you think.
    Peace,
    NoFear
    Member
    Central Coast Australia
    47
    Hi everyone,
    I've had an idea about using a node as a winding to run a small window motor for some time, I've found a opportunity to try my idea!..., and to my surprise it worked!..., the window motor seems to spin as almost as fast as the ssg, the winding is not connected to any transistors, just in series with the power winding as a node.
    This has got me thinking that with a multi strand coil, there could be multi nods with a window motor running with no extra input.
    Is there anyone in the group that has done this before?
    George N.
    1,513
    Hi Tom C,
    Your Avatar picture of JBs drawing is best describing this experiment.! The single wire that JB is talking about is the air core inductor across which is placed the FWBR..another FWBR is used for the full re gauge version as depicted in the same drawing.
    this is converted version of his Pat#6545444.
