Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Another Newbie having trouble with his SSG
    Netherlands, The Hague
    112
    Yes 1n4001 from emiter to base
    and 1n4007 from collector to charge battery
    those diodes will work... the mjl21194 is a lil more robust and doesnt fry as quick.... check that base resistance and make sure its pretty low(make sure you use the middle prong on the pot cuz if you use both outside prongs the knob wont actually change resistance)
    Quote Originally Posted by Marksman View Post
    I will check the diodes both ways. Thanks for the info. Sorry if I seem a little uneducated in this field, because I am.
    I am using 1n4001 and 1n4007 diodes. Are these fine? As for the transistor, are there any others better suited for the job?
    Thanks.
    Hi, the ideal transistor is MJL21194, but it should work with 2n3055 also. The diodes are correct.
    In my first SSG years ago I fried lots of 2n3055, mostly because for some strange reason I insisted in disconnecting the charging battery.
    best,
    Alvaro
    Thanks for the info everyone. Busy today working on my car but I'll get back to this in the near future.
