Watson coil design
  • Watson coil design
    Any ideas on the long thin coils seen on the Watson machines.
    Reason for length - increased core material?
    Small wire for thin coils?
    What do I want for current from the coils to pulse charge a pair of golf cart batties?
    #of winds?
    I'm doing testing but have no intuition on these coils.
    bro d
    4 big neo's and 3 aircore/500ft #18 wire coils did much better than 6 ceramic ring mags and 5 of same coils/bolt cores.
    Neo's spun at 2000rpm
    Rings at 1500
    Concluded: smaller wire to get voltage up with rings and r60 cores.
    Ring mags are about same D as Pittsfield spools and we're spaced with ID and distance between mags the same.
    Rings were mounted on wood rotor 1 flew off and went into the sheet rock.
