Page 19 of 22 FirstFirst ... 91718192021 ... LastLast
Results 181 to 190 of 211
  1. #181
    jamesgray3rd, Thankyou for your comments. It is amazing, you can see from all the scope shots of the battery ringing, it doesn't matter if it is triggered from stay frequencies from DC-DC converters, or if the "4 Battery Bedini Switch" is having bursts of battery resonances while running, or if I Tap a screwdriver on the output.
    The frequency of resonance is always the same.
    Very Interesting.
    Super Ultra Awesome
    Most
    kindest
    Nityesh Schnaderbeck
  2. #182
    Great work Nityesh!
    Hi Nityesh,
    That ringing looks a lot like the ringing I get with my SSG on both batteries. When I expand it out, it usually reads 833MHZ on the scope. I assume the frequency is determined by the battery impedance? I use a small sniffer coil to pick up the signal from the battery leads.
  4. #184
    Hi Gary
    Hmmm...you can do that???
    Best regards
    James, somewhere in Idaho
    ~ Padmé Amidala ~
  5. #185
    Hi James,
    Quote Originally Posted by jamesgray3rd View Post
    Hi Gary
    Yeah. Here's a link to one of my old posts from my old machine. My newer machine throws much bigger spikes and ringing than the old one. http://www.energyscienceforum.com/al...achmentid=2227
    Last edited by Gary Hammond; 11-22-2015 at 08:55 PM. Reason: correct spelling error
  6. #186
    Hi Gary
    I looked at that...and...SWEET! I gota' have me one! Please share the specs on your sniffer coil!
    Best regards
    ~ Padmé Amidala ~
  7. #187
    Here is another scope shot, looks like the battery is changing polarity, for a very short time, like a back emf of a coil.
    Could it be that this, changing polarity, for a very short time, is showing a type of electricity that lights a reverse biased LED.
    It would be good to find out if any one else can get similar scope shots, just to verify things.
    Kind
    Nityesh Schanderbeck
  8. #188
    Hi Nityesh, I have seen spikes like that on some of my Tesla Switches. But I don't have one running right now.
    I do have a Ron Cole Par Switch that is semi operational I can check for you.
    @James, if you can find a scrap MWO get the coil out of the turntable motor to use as a sniffer coil.
    Thankyou John_Koorn for your help and comments.
    I turned off everything that could cause interference, smart phone, external hard drive, etc. Except For the computer I am running the scope interface on.
    I found out that sharp transients from the environment can also trigger battery ringing. A sharp magnetic pulse can also trigger a sniffer coil to resonate.
    Here is another method of monitoring the effect of back spikes on the battery, I thought I would share an old experiment.
    The sniffer coil shows current pulses into the battery, while the below method sees the voltage spikes across the battery without disturbing the charging. One method(sniffer coil) sees current pulses and the bellow method sees voltage pulses, it depends on what you wish to do.
    Connect the capacitor end across the charging battery, and connect a scope to the coil. You can adjust the signal gain from the number of turns on the coil. Using Litz wire will help, a lot the see the high frequency transients.
    Thankyou everyone for your posts
    Most
    Kindest
  10. #190
    John K & Nityesh
    John. Assuming next, I then hook my scope lead to one end and the ground to the other, and then place the core close to the cable?
    Thank you both.
    Best regards
    ~ Padmé Amidala ~
