Increase your RPM with wider tape!
  • Increase your RPM with wider tape!
    I added 14 RPM just by using wide tape on my wheel! Silly thing is I used wide tape early on in my builds, then switched to thin tape as its cheaper as I was swapping out magnets a lot during some tests.
    The thin tape on my wheel was threatening to let my magnets loose last night so I reinforced it with wider tape and noticed my RPM increase from 470 to 484!
    Would be nice to enclose all those suckers with a heat shrink or something to really reduce the wind resistance.
    Just realized my subject line reads like one of those ads for gentleman. lol
    COVER THE RIM IF YOU HAVE A WHEEL WITH MONOKOTE AS YOU WOULD COVER A MODEL R/C AIR PLANE
    ALL YOU NEED IS A IRON [A HOUSE IRON WILL DO ] DONT USE THE WIFES UNLESS YOU CLEAN IT GOOD
    http://www.monokote.com/
    https://www.youtube.com/watch?v=FAmkzUJO0-Y
