Cap dump 1 to 1 ratio.
  • Cap dump 1 to 1 ratio.
    Hi Guys,
    What does 1 to 1 ratio for the cap dump coil means. Does it mean I would only have a trigger coil, main coil and cap dump coil ?
    What if I have 7 main coils, do I need 7 more cap dump coils and the circuits? Because I have 7 main coils now and the schematics shows 1-1 ratio for the cap dump coil .
    Thank you!
    Regards,
    Mark
    not sure what you are asking, and what is it in reference to? most machines have 1 coil with 7 or 8 strands and 1 trigger. there is not a cap dump coil...... the coil output feeds the comparator which charges up capacitors and then that discharges to the battery.
      Hi Tom,
Name:	5 November 2014 074342 GMT+0800.jpg
      In the attached picture,the coil on the right side of the schematic. Should I make another solenoid with 7 wires and 7 circuits for the original bedini sg?
      Regards,
      Mark
        that coil picture is not from the SG it is from the full monopole, it is a different beast...... it is a trifilar. are you building a full monopole?
          O my, I am not aware of that. I thought the the coil in the intemediate handbook will be a supplement to the existing SG. . So this is a totally different system with only 3 coils? Trigger, main and capacitor dump. ? If so, how can I use capacitor dump for my existing SG.
          Thank you for answering my many questions. haha.
          Regards,
          Mark
            it is 1 coil with 3 windings..... when you say 3 coils, you imply 3 separate coil spools. as far as your existing SG you simply hook the output of your SG to a cap dump circuit, then hook the cap dump to your battery. please post a pic of your machine so we can see what you are working with. the advanced handbook has a separate generator coil that is outputting to a diode string. it is a stand alone coil not part of the SG circuitry.
              This is a picture of my system. Click image for larger version
              It is a 3 Coil(4windings) +1 trigger bedini SG circuit. So the cap dump for my circuit is to get a standalone circuit to connect between my machine and battery ? The circuit I in the intermediate handbook ?
              For the advance handbook is there step by step like the beginner's handbook for the trifilar ?
              Thank you !
              Regards,
              Mark
                you can buy one here:http://www.teslagenx.com/research/tx...egory=research they are built by John and Chuck. or you can look at
                the ultimate cap dump thread on this forum. there are lots of circuits there.
                  Hi Tom,
                  Thanks for the info!
                  Regards,
                  Mark
