Page 6 of 6 FirstFirst ... 456
Results 51 to 60 of 60
Thread: Bedini SG - The Complete Advanced Handbook
  1. #51
    Hi I have always wanted to try swapping a couple of big boost cap banks to see how well that would do just because they can convert the radiant so efficiently. So if someone has some big supercaps and would be willing to give it a go or has tried this I would love to see how it worked out. I just haven't spent the money on a big super cap bank thus far however one day I want to.
  2. #52
    Aaron and Peter i would love to thank you for you hard work , not only you provide beginners information you are actually doing more.
    Now we established clear procedure's how to build stuff and which battery type should be used.
    Personally i found very interesting the part where Peter mentioned low impedance of wire , in my circuit i use a lot of wire , and this wire is different to coil wire.
    As result i try to replace the wire with wire which i used for my coil, hope it increase the output of my machine!
  3. #53
    Heart of Vermont
    306
    Hey Mon lighten up, perhaps you have been watching too many RT videos and news. Stick to the subject matter and the science - please leave the politics and diatribes at a more appropriate forum.
  4. #54
    casstete
    Well i sorry for you, that you can't recognize peaceful symbols. Personally i am on such knowledge level , that i would prefer to work for cia in black project operation, rather on day job which i currently have. Well casstete i will just ignore you..
  5. #55
    I was saddened to hear of the death of Mr John Bedini ....
    He was a visionary ...
    I just wanted to mention that I think Aaron and Peter's work in the Bedini SG series of books is amazing and totally honored John bedini's life and legacy.
    Hais.
  6. #56
    I got back into my little ssg motor that I posted in this thread 2~3 years ago.
    At that time I had it with a bifilar coil for the motor, 1 trigger and 1 power winding. Now I made a larger coil, with 8 strands of wire, 1 trigger, 7 power.
    The circuit is the same as the advanced book, but with small transistors, 2n2222. All matched up and everything.
    It runs much faster!, with the old coil it ran 3000++ RPM at 12 volts. and everthing got hot, the coil and transistors.
    Now with this coil I have not tryed to run it on 12v... yet.
    with 5v input from a phone charger, it runs at 3600++ RPM. o.O
    in the past I wondered why mine droped a lot of RPM with the gen coils in place (not connected, just drag from the iron cores). And the SSG from the advanced book didn't drop any RPM with the gen coil. Now I see that I had 1 power winding, and 6 gen coils... the SSG from the book had 7 power windings and 1 gen coil... totally different story.
    I have to start new tests now, I have to get other batteries because the lifepo4 that I had at the time are not in the best shape. And I want to try with normal batts, I might get some new 6v 4ah batteries. And see what happens on 6V. It might get up to 4000 RPM.
    I don't want to run it on 12V because I am afraid that those magnets escape from the rotor or something. I have to make a better frame...
    I might put all 6 gen coils back in, out of phase each with independent diode charging a cap dump circuit. I also have to experiment with the AC cap that John had in the 1984 booklet in the gen coils.
    here are some pics that I took just now, with 1 gen coil going to the new cap dump circuit that I made.
    best
    Alvaro
  7. #57
    best
    Alvaro
    2n2222 - Nice!
    Try running it on your 5v and charge the 12 volts, maybe with a simple cap dump via larger transistor or just straight to the 12V...
    KR - Patrick
  8. #58
    2n2222 - Nice!
    KR - Patrick
    Tnx Patrick, I choosed the 2n2222 because they are much cheaper than the MJL21194.
  9. #59
    Nice work Alvaro!
    Nice work Alvaro!
    Tnx John!!! You are very kind, as always.
