Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: My First Window Motor Replication
    1,529
    I built this new window motor out of wood and have a question about the energizer coils. First of all I would like to give a description of the build and materials. The window magnet rotor uses two neodymium magnets (2"X 1" X .5") which have a 75 lbs pull force. The wire is a single 19 AWG at 75 turns or 150'. The shaft is 5/16" steel threaded rod rolling between two skateboard bearings (8mm id). I am using a commutator to switch on/off. It spins at just over 5000 rpm's with no load attached. It is interesting that the voltage on the multi-meter jumps all over the place when the motor is running. The battery is a 19.5V Craftsman NiCad drill battery that normally has a resting voltage of 21.2 volts. While the motor is running it jumps around from 28V to 50V. It does lose power over time and there is a reduction in rpm's. This is only a short-term observation.
    I expanded on the design and added the energizer section. The energizer magnets are 12 .5" X .25" round neodymium. I have studied the Advanced book on the generator coil as well as information on the potential energy that is obtained with the Tesla bifilar coil. I am assuming that it is somewhat of the same concept. I will be using 1/16" bundled welding wire for the cores. My question is there a certain gauge of magnet wire that I should be looking to install on my coils to get a desirable affect? 10 strands of 1000' of 35 awg in series? 2 strands of 22 awg in series?
    Thanks for any input!!!
    Doug MannAttachment 5148
    Nice work mann..
    Schone....
    Faraday88
    https://www.youtube.com/watch?v=kIuZmC5SNc4
    This is my next window motor. I have got two 19awg strands in series running the motor. The window motor rotor has six poles on it that are in the NSNS arrangement. The motor is only getting pulsed once per revolution. You will see the energizer section added to it. There are six coils on it. Each coil has 400T of 23awg on them. It is not connected yet. The rotor on the energizer has 12 half inch neo's on it that are a quarter inch deep.
    Enjoy,
    DMann
    https://www.youtube.com/watch?v=u6K-dDRazhU
    This is the 3rd video for this motor. I have the energizer hooked up feeding back to the run battery. It is being pulsed through the commutator. The voltage is being read across the capacitors. I could probably benefit from a large flywheel on this setup.
    https://www.youtube.com/watch?v=L9IsJHXoc2U
    This is version #4. It is a larger motor with four wires in parallel for power. I can get 1000+ HV readings from this setup if I put pressure on the contact points.
    https://www.youtube.com/watch?v=UM6ZnYWQMb0
    This is with the 1000+ HV commutator spikes
