Page 1 of 26 12311 ... LastLast
Results 1 to 10 of 251
Thread: John K's Superpole Bike Wheel SSG
    Here is a modified bike wheel SSG I recently built. It is a 27" alloy rim on what seems to be reasonable bike wheel bearings, originally made in Belgium.
    The magnets are 18 pairs of 50mm x 20mm x 12.5mm ceramic #8 in super-pole configuration that are bonded to the rim with Selleys Liquid Nails High Strength. The wheel was then balanced by placing small pieces of lead on the spokes until there was no more rocking. Even though it has a slight wobble in it, I get over 25 minutes free spin time.
    The coil is 5 x AWG#18 all 125' all 1.2 ohms, wrapped on a 90mm x 85mm Pittsfield spool with 1.6mm R60 welding rods for a core. The core is 18mm diameter.
    The board is 4 x MJL21194, 100 ohms on each base, 50 ohm master resistor, 1N5408 - all matched.
    Batteries are 12V 50Ah gels, used for a test run.
    Machine likes to run at 0.5A draw current @ ~140RPM. Nothing gets warm at all.
    I am currently doing the first load test, will post the results when they are done.
    Thanks for watching the video.
    Beautiful, John. Very elegant.
    h
    John K,
    The energizer looks good, when you plot the chart I would like to see that.
    I have that kind of battery at work and they should not be pushed over 14.8 volts. try to just get one resistor in series with the trigger, it looks like it would be 220 ohms.
    Great work on the super pole energizer.
    John Bedini
    love it JOHN K I allways wanted to build spole on a bike wheel
    dang those are big gel cells [batteries]
    zzguy
    John B,
    Can you teach us something about what you just said? John has two 100 ohm resistors in parallel that he's calling the 50 ohm master resistor and he said in the video that it is in series with a 10 ohm branch resistor which is in parallel with a GOW bulb. How do you judge that he can replace those resistors in series with a single 220 ohm? Do you mean 220 ohm in parallel with the GOW or leave out the bulb entirely. I know I will never have your intuitive understanding of the circuits but how you do this is fascinating to me and I'd love an insight into your thinking process.
    thanks
    h
    John K,
    John B,
    Here is the first load test. I got 44Ah out of the battery, which is about the same as what I took out of the primary. So I am about 1:1 charging on the first cycle which should improve with more cycles. Let's not forget that it ran that bike wheel for 4 days so if I add in the mechanical energy I am way over the top.
    What I'm going to do next with the setup is attach a battery to each of the collector diodes, so 4 batteries. These will be dried out gel-cells that I'm going to restore using your method.
    Superpole Bike Wheel_T1.zip
    P.S. The two trigger resistors are 100 ohms each, so I'll swap them out for a 47 ohm single resistor.
    Nice John K.. cant wait to see next cycle
    Alfin
    Member
    Adelaide, South Australia
    67
    That was quick work! I'm still building my 5-filiar set-up. It takes a while to get all the bits together down here. Twenty-five minutes + free spin time is awesome! I'm buying a 29" wheel with ceramic bearing pack... might take a week to get here. Do you think the better spin time is on account of the double magnet weight? It's good to see you finally built one using just Liquid Nails U.S. I balanced my last wheel using just Liquid Nail on its own. It's very good stuff, nice & tacky, but takes about a week to dry to full strength. Very, very bad for fingers (took me six months to get over the last time I accidentally got some on my hands)! How did you go with Litzing the coil wires? Do you notice any difference with / without the flange? You've certainly set the standard high!
    Hey Barrie,
    Yes, the extra magnets give a longer free spin time. It also makes a great flywheel. The Liquid Nails is great, I get a few minutes to set the magnets into place and yes, I waited a week for it to go off properly. It also took a fair bit of scrubbing in warm soapy water to get it off the fingers. Better than super gluing your fingers together though
    To twist the wires I put an eye bolt in the drill chuck and attached the wires and twisted one end. Then the same for the other end. Note that my wires were attached to the back fence on one end and then attached to an old battery on the other end. The battery was for weight to keep it the wire tight, not for power.
    I twisted the wire attached to the battery first as the wire bundle gets shorter when you twist it. Then I attached the wire to the battery again and placed the battery so as to take the slack out. Then I twisted the other end that was attached to the back fence. Once it was twisted I started to wind the wire onto the spool from that end first and walked towards the battery as I wound.
    To be honest, I did not notice a big speed difference with the flange, maybe 1 rpm. I adjusted it up and down a few times. I'm kind of flying blind here and will have to wait and see what effect it has on charging.
    Sorry to split hairs here.
    Is that 125' length with the windings twisted together?
    Or
    walk out 5 125's, twist them up, and the length is what it ends up being?
    Thank you.
