Results 11 to 20 of 25
Thread: Acheiving Over Unity With A Empty Coffee Cup
    Pre-Construction Meeting
    Introduction
    We often associate Nikola Tesla with high frequency energy broadcasting electricity through the air with transmitters and receivers, what we most often do not ask ourselves is how did Mr. Tesla conceptualize his theories - he conceptualized his theories by making basic observations of nature, natural law, and then applied those findings to existing systems improving upon them from the viewpoint of his conceptualizations. We often forget that Mr. Tesla did not invent scalar energy, that while he was an inventor he was also a business man in the business of making money. All of Tesla's inventions do nothing more than take advantage of what already exists in nature that is available to each of us.
    Attachment 3842
    Which came first the experiment, or the concept?
    A Note from Colorado Springs, Colorado - Nikola Tesla's Research Facility June 1, 1899 and Jan. 7, 1900
    "The earth is 4,000 miles radius. Around this conducting earth is an atmosphere. The earth is a conductor; the atmosphere above is a conductor, only there is a little stratum between the conducting atmosphere and the conducting earth which is insulating. . . . Now, you realize right away that if you set up differences of potential at one point, say, you will create in the media corresponding fluctuations of potential. But, since the distance from the earth's surface to the conducting atmosphere is minute. You can readily see that the energy cannot travel along this curve and get there, but will be immediately transformed into conduction currents, and these currents will travel like currents over a wire with a return. The energy will be recovered in the circuit, not by a beam that passes along this curve and is reflected and absorbed, . . . but it will travel by conduction and will be recovered in this way."
    "Under ideal no-load conditions the movement of electrical energy throughout the system appears to be totally reactive and only when electrical loads are present does real power flow."
    -Nikola Tesla
    Attachment 3841
    Note: In our circuit our Source will provide conduction.
    For your listening enjoyment...
    Grab a cup of coffee, lots of concepts here. Will be posting the other two hours later today.
    Last edited by longhorn; 09-23-2014 at 12:41 PM. Reason: Repost of video that was rejected by Youtube
    Here is a concept I have been kicking around for our circuit.
    Quote Originally Posted by longhorn View Post
    "The object of my invention is to provide a more certain and satisfactory means for use with and control by such machines or apparatus as I have mentioned for producing sparks or discharges of the desired character, and to this end I employ the following arrangement: Any suitable moving portion of a the apparatus is caused to mechanically control the charging of 'a condenser and its discharge through a circuit in inductive relation to a secondary circuit leading to theterminals between which the discharge is to occur, so that at the desired intervals the condenser may be discharged through its circuit and induce in the other circuit a current of high potential which produces the desired spark or discharge."
    -Nikola Tesla, U.S. Patent 609250 (SEE: http://www.google.com/patents/US609250)
    Will repost later have to remove this
    http://www.youtube.com/watch?v=miwVZWOKivg
    Hour 2 of 3 Telluric Current
    Last edited by longhorn; 09-23-2014 at 03:14 PM. Reason: Repost Edited Hour 2 edited for alleged copyright indiscretion
    Hour 3 of 3 Telluric Current
    Hope there is no Hellraiser problems here.
    In our busy live's attention spans short, per-occupations and personal pursuits work to limit our local time domain. The video I posted in three parts; Telluric Current is in my opinion one of the most important resources available to us and I would recommend it's perusal to be paramount in our quest of achieving free energy.
    So in a nutshell here is the short of what's most important to us from Hour Two of Telluric Energy (or Current) in our current discussion, for conveniences sake.
    It is paramount to understand as we build our magnetic dipole single wire circuit in the local time domain - Magnatricity!
    Construction Note 2
    Dipole Theory
    Introduction
    Disequilibrium electro magnetic systems (dipoles) active with their local environment perform five functions that is impossible to achieve in equilibrium systems, powering itself and it's load without any user input.
    Disequilibrium EM systems can:
    1. Self order.
    2. Self oscillate of self rotate.
    3. Output more energy than the operator inputs.
    4. Power itself and its load.
    5. Exhibit negentropy.
    Ibid: Energy From The Vacuum: Concepts & Principles pg. 588, Tom Bearden; 2002.
    Quoting Bearden directly.
    “Any charge or dipole already exhibits all five of these functions.” (pg. 588)
    “The known performance of the charge and the dipole totally refutes the notion that no EM system can output energy without operator arranged input from other than the active vacuum.” (pg. 589)
    -Energy From The Vacuum: Concepts & Principles, Bearden
    What is implied by Bearden's latter quote above is; that an electro magnetic (induction) system can:
    'Power itself and it's load if it is a self oscillating dipole open system operating in the local active environment; without ANY user input.'
    In our circuit that we are building conceptually we have an elevated wire that is earthed between two dissimilar metal plates which sets up a magnetic current in our dipole which is in disequilibrium due to the electromotive force established by our circuit's earth plates. If we wanted a dipole in equilibrium with the local environment our earth plates would be of the same material without conduction current. Remember that where there is a magnetic field (dipole) there is a current induced but we must overcome the natural tendency of all dipoles to remain in a state of equilibrium.
    "There is enough energy inside the space in an empty cup to boil all the oceans of the world. This is a fact well known to
    the scientific community, and was, for example, a favorite quote of Nobel Prize winning physicist Richard Feynman."
    Source: http://www.cheniere.org/
