Page 1 of 9 123 ... LastLast
Results 1 to 10 of 90
Thread: SG8 Pot location
    SG8 Pot location
    I understand for to tune the SG8 that you need to replace the 470 ohm base resistors with 100 ohm base resistors. On what area would I place the pot on the SG8? Here is a pic of mine:
    place the potentiometer in the spot where the 12 ohm resistor is.
    Hi Yoe777 and Tom,
    still not clear to me where to put the pot... here a pic of mine, could you explain where exactly put the pot ? From where to where...
    I put numbers to make it easier to explain.
    please help
    thank you
    Quote Originally Posted by claudio View Post
    Hi Yoe777 and Tom,
    please help
    thank you
    Remove the 12 Ohm resistor and put the Potentiometer there...
    Heart of Vermont
    350
    Hi Yoe777 and Tom,
    please help
    thank you
    Claudio - in your picture the adjustable pot goes between terminals 2 and 4 replacing the 12 ohm resistor.
    Thank you guys, will try and post the results !
    I would leave the resistor - remove the trigger coil lead from 4 - place a pot between the trigger coil lead and terminal 4 of the 12 ohm resistor. make it a nice beefy POT. It's ok if you already did what they say worse case you burn the pot and run the circuit on the individual base resistors, I hope...
    thank you so much for your advices...
    I have another problem:
    I'm having difficulties to install the Analog Amp meters, what is the correct way? Do I need a specific shunt or is there another way to install them ?
    please help
    please help
    You may simply place the Ammeter in series line of the side you want to measure the current at. like in line with the primary or secondary circuit.
    what is the scale- range of the Ammeter you have..?
    do you have one or two of these Ammeter. in that case you can have one at each side of the circuit.
    no need of additional shunts..
    yes right, in fact it was a non sense request...
    Ammeters are 0-3 A and 0-5 A I guess both will do the job..
    thank you again for the support !
    all the best
    claudio
