Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 114
Thread: Ferris wheel thread
    why all the info? we can build it without knowing how it works, and it may run, but if it does not we need to know why. but understanding magnets and magnetism is the key to all free energy devices. the magnet is a dipole and it pours out excess energy for years, way more than the original number of joules used to create it. we will eventually build and run all the devices mentioned on this forum. its all about the same thing, whether it is a permanent magnet or an electromagnet.
    this has been one of my favorite illustrations for years.....
    http://wmsn.net/Adams%20Motor%20Theory.htm
    copy the gif and then enlarge it on your pc so you can look at it.
    Tom i get an error 404 on the link
    'dual band flux path inductive reactance capacitive non coil saturating switched at the delta phi' sounds like a to me
    Tom,
    All these links are a treasure trove.
    Thanks for sharing them.
    Here is the link that is messed up below.
    Go to http://wmsn.net and you have more...
    Quote Originally Posted by bigmotherwhale View Post
    Oh my god, why have i not seen this before?
    'Demagnetization is a fundamental over-unity concept!'
    i like this alot thanks
    Treasure indeed !!
    Thanks Tom C !!
    Lman
    its not "demagnetization" per say, more like a manipulation of the field, like the radus patent, like leedskalnin, and like the coils in the ferris wheel. like I said we will all get where we want to go together.... we are almost there. just need to understand the operational theory behind the coil asymmetry in the ferris wheel. then we can build it.
    I am assembling a timing disc right now. I purchased a plastic disc from tap plastics and some round ceramics from home depot. since I am making a small ferris wheel I am using 3/4 disc magnets. this is for the hall sensor.
    here is an instructable for making a center finder. http://www.instructables.com/id/Make-a-Center-Finder/
    360/16 = 22.5 degrees on center for each magnet. this can be done with a 1/2 inch drill bit and a 3/4 inch paddle bit. use a drill press if you have one.
    ======Adams%20Motor%20Theory.htm==== CUT PAST TO GOOGLE
    FOR http://wmsn.net/Adams%20Motor%20Theory.htm
    http://www.fleadh.co.uk/srm.htm
    Now I see why Leedskalnin had all the chains hanging and things around his wheel.
    Lman
