Page 2 of 12 FirstFirst 1234 ... LastLast
Results 11 to 20 of 114
Thread: Ferris wheel thread
    the fist step in the ferris wheel is the half bipolar circuit or half bedini-cole circuit with a bridge on the output. understand how that circuit functions and then you can run a single coil on it. 16 magnets on your wheel. I do not know if we will need the small neo for shaping the field on this size rotor. it may be advantagous as the magnets are farther apart and it will help create the scalar south.
    changing inductance of the coil on the ferris wheel on the fly is the key to it's function. this can be done several ways. if anyone does not have the DVD set from JB on the ferris wheel its a great start. He has given us so much I do not have a problem purchasing those so he can keep sharing. if you cannot afford them I totally understand we will do our best to share openly and simply.
    then we can work together on the idle magneto in the center of the wheel.
    we will talk about inducing the pulse into the primary coil and where it is to be pulsed. this will bring us to a multi coil machine, and then to an AC version of the same machine. with alternating magnet rotor, and close coupled coils switched at the zero crossing point of the coil.
    I am on this journey with all of you, together we can make an amazing discovery!!
    every thing must be shared openly in simple terms that we can understand. it is easiest to understand in laymans terms as opposed to engineering terms. words like dual band flux path inductive reactance capacitive non coil saturating switched at the delta phi may be fairly descriptive but it leaves you saying huh?
    lets keep it simple and descriptive in a way that lets non engineers understand what is happening.
    Aaron 1gt.jpg here is the simple bipolar switch with a single wire coil.
    I'm on it as time allows...
    here's a good post:
    "@all,
    Yes the inductance does change when the magnets pass the pole. The one thing that you can not do in the machine is twist the wires. Now each wire in the main coil has it's own resistance so this is offset a little when it turns on sort of like a mag amp but pulsed DC or more like PWM because of the switching so I had to sit and tune it for maximum power low RPM.
    This is a very tedious to do as if I did not get just right I could not self start the machine. No one posted a Video of me showing it at the convention yet but someone out there has it. When I would start it from a dead stop it would accelerate backwards and slam agents three magnetic fields and dead stop then leap forward right up to 16RPM's that is how I knew I had the timing right. You all have done excellent work on this group. But now I'm going to do something I always wanted to do with a new machine just like this we must make it run with no input. Great group glad I could be here.
    John B"
    Is this a good enough schematic of the half bipolar Bedini/Cole switch using hall?
    from this post.
    I remember using this with great success.
    Kind Regards
    Patrick A.
    I took too long to hit "post" :-)
    so lets understand an inductor http://en.wikipedia.org/wiki/Inductor for now the math is not important but to understand why our coil is an inductor is important.
    we also need to look at why there is capacitance in a coil. when you lay 2 insulated wires side by side and pass current between them the air gap acts in the same way as the separation in the 2 halves of a capacitor. hence we can use the terms inductive capacitance, because it is related to frequency and it can be manipulated .
    http://electronics.stackexchange.com...gh-frequencies
    I don't know if anyone was at the conference where Paul Babcock did his lecture on the math behind his coil array where he could weld 1/4 inch steel together using a big coil and a little tiny battery. he interchanged the inductance and capacitance formulas to show how the math proves it can be done. not important for now but I have seen these 2 formulas mixed in a very unique way to produce real work.
    Wink astable 555 timer circuit
    we will need this down the road, so everyone print this out and sock it away for the future.
    http://www.instructables.com/id/555-...-Astable-Mode/
    a quote from JB:
    My intention was not to hide anything you were free to touch it examine it and run it if you wanted to. I was just standing around to help.
    John K take your monopole single coil machine and use the Bedini/Cole switch then shape the field of the bottom coil like I did. Do the timing wheel right use a hall and collect everything from the switch to the capacitor and dump the charge in seconds according to the charge rate, you will see.
    John B
