Page 11 of 12 FirstFirst ... 9101112 LastLast
Results 101 to 110 of 114
Thread: Ferris wheel thread
  1. #101
    bigmotherwhale,
    The 10 coils on the axial idling magneto are in series but the three coils on the bottom are in parallel.
    Lman
  2. #102
    Oh i see, that's what i must have been looking at, thanks Lman
  3. #103
    sorry I have not posted in a while, teslagenx is getting new digs!! still framing the walls, trying to get things finished before the rains set in, at least get it watertight in a few months I will have a new space for operations. it will be off grid and bedini powered. people often wonder why no one is powering their "house" well it wont be the house but it will be powered it is getting DC and AC wiring parallel and a tracker 5 for the batteries, a big monopole for rejuvenation and a big linear regulator for loads off the SG. wood stove heating and a composting toilet.
    everyone please post your work on this thread. thanks Patrick for stepping up and showing us what you are doing.
  4. #104
    Important patent, very good easy to understand explanations, pay special attention to lead in / lead out asymmetric explanations http://www.google.com/patents/US7109671 and the use of Back Emf Strain in the system to drive the rotor forward instead of EMF
    Also after finishing my switching circuits and they are working well, I have dismantled my old ****ty test wheel and i am looking to make a new rotor, this is the most important part as it will determine what sort of machine i have to build. I have my old magnets which are ferrite very weak and will need to be stacked in threes, this will also mean i will have to use a ferrous core, and probably solenoid - not brilliant. I have considered Neodymium, i have the power available to use them, If i was going to use these i would not use a ferrite core and would use a window motor style coil to magnet setup which has a lot of advantages. obviously it would not be like the Ferris wheel, but the principles are the same.
    the other choice is between axial and radial. This is a difficult decision any help or anything i havent considered please let me know. The materials i have at hand are very thick plastic chopping boards, Ialso have a few alternators which would make good bearing supports and should bolt onto a plastic disc with ease, however they have a huge chuck of iron in the middle not sure how much that will affect the running of the machine.
    Thanks people
  5. #105
    Why this thread ends here????????
  6. #106
    life....... the ferris wheel is a complicated device and requires a lot of time and energy..... if you have any questions please post them here and we will try and answer them.
  7. #107
    Yes I have some questions (as always) but I will post them in the thread that I already started about my little machine, I don't wanna post my mini machine in the ferris wheel thread, it's odd. But it would be great to have more material to read, I was reading this thread yesterday and it was great.
    Alvaro
  8. #108
    Wow! Tom your doing some great work here. Clarity is everything. Sorry it has taken so long for me to pop in and see what you've been up to. There is some great info here.
    I only have a few minutes to comment, I spent most of the evening reading the entire thread. And I will try to add a few things I have learned along the way. one thing I see is that some clarification on impedence inductance and resistance may help here. (I won't go into inductive reactance) They are not the same thing. The resistance values that JB gave are in R and I. I tried to make that distinction before and am afraid I made it all to complex. Perhaps a simple analogy.. if you take some corn starch add some water then try to stir it you will begin to see what is going on when the coils come alive. I think Tom, at the begining you said everything is timing. For me it is frequency. When you try stir the starch there is a speed or rate where it goes smoothly. push to fast and it brings you to a halt. The coils want to run at a very specific frequency. I have found that every build I've done is different. This is part of why JB used round magnets on the hall. As current flows into the coil there is a rate of time(pulse width) before the coil is charged. After that it is just a short circuit wasitn energy. so you want your pulse to end at exactly or just before that point where the coil becomes "saturated" This is done moving the hall from center of magnet outword, longer pulse to shorter. Then you also have to "time" by moving the hall across the arc of movement to fire at the just the right moment. I had a lot of fun with John K. playing with the timing for everyone to see back then. But as you move along the arc, several things happen at the same time. The rpm's are affected, and so is the current. There is a balance to watch for. But: there is a third component I discovered. And this is something I am not sure anyone ever talked about. And that is the sound. on one of JB's videos he was showing and talking about his ten coiler. he mentioned the thud thud sound it made. I discovered this with my smaller Ferris. At a certain point it would become loud and clear. On that machine, at the time, I was running 3.2 amps 20 volts, using two very large Alum converted batteries.
    The unanswered or never really clear question I still have is if the outside coils are supposed to be polor opposite of the center coil, or are they supposed to be the same polarity as the center? I was running them in attraction mode with the center coil repulsion. JB's answer to John K. made it sound like that's how he always did it, but I always wondered. when I experimented on my machine and ran the numbers I did get about 35% efficient when the outsides were opposite the center. and about 52% when they were all the same. very much the same as my six coil SSG. which fits in with the intermediate SSG manual as I recall.
    Something interesting I had happen while playing with my mini ferris, was that it was on a table. below the table on the floor was one of my favorite SSG's. The ssg was hooked to an input battery and had been left just sitting there. When I turned on the Fereis wheel, the neons on the SSG began to fire. I always beleived the ferris was capable of wireless transmission of power. I would love to know if thats what it was. but it may have just been a mag field crossing the trigger wre just enough to cause it fire, and nothing more. I had it happen again a few months ago when I dusted everyting off and was playing a bit. But since then I gave the SSG to a family member and nothing else has worked. But with the post on the portals between the sun and earth.....I dunno!
    Lesk
  9. #109
    5' Ferris Wheel
    I am selling my 36V, 5' Bedini Ferris Wheel for just material costs, $1500 plus shipping. I'm unable to post pictures here on the forum but can attach to emails. Post a message here to me if anyone is interested. Also for sale; one 60,000uF cap dump, $125 and the coil assembly of one 32" diameter re-gauging motor, $525.
    Ron Chase
  10. #110
    Ferris wheel Pictures
    Thanks Aaron, here are the pictures of the Ferris Wheel, Cap Dump and half the re-gauging motor that I'm selling.
    Ron
