Results 1 to 10 of 13
Thread: Superpole?
    Question Superpole?
    Hi all!
    I have a general question about superpole (two magnets north pol to north pol glue together):
    I know when you take two magnet's you make one strong magnet, i saw some videos from various forum members and i would like to know if this superpole better performing than single magnet.
    I mean is it appropriate to use in one transistor circuit , or only suitable for circuit with many transistors?
    If this superpole is advised for use with many transistors circuit , than i would like to know with which pole iit passing over the coil (with south or north pole ?) .
    example:
    on my wheel all magnetpoles are north (means pole directed towards the coil)
    coil pole is north too.
    I found this picture on energetic forum
    You can use superpole magnets with a one transistor circuit. It doesn't have to be for multiple transistor circuits.
    the picture you posted is the way the magnets should be for superpole.
    Thx John, i just wonder what is the reason behind superpole usage?
    My best guess, by creating sharp and stronger nord pole i would be able to catch more impulses to comparison with normal magnet.
    1,513
    Hi BEDINSSGUKRAINE,
    As always, I am sorry to chime in here but here is how I see the Superpole Monopole concept.
    the squeezing of the two N-pole (even S-pole is applicable) is one of the 3 -modes of creating the Scalar-construction of the Magnetic Field on to the Rotor of an Bedini Energiser,
    the 6-pole ,the 12-pole have one type of the Geometry of the Scalar-Structure, while the most advanced (I have yet to realize what it would be like) is on that 10 COILER.!!!
    The experts will correct me if I'm wrong..
    Best Regards,
    if someone wants to know
    my experience is, the superpole is very sharp..
    but its inducing less volts in trigger winding !
    so you will fight to get the trigger running.. and when it works.. then you will see,
    that the powercoils are not powering the wheel as good as the standard magnet configuration..
    the wheel will turn slower..
    i went back from superpole to standard..
    here some fotos from
    http://rgey.de/wp/?page_id=874
    http://rgey.de/wp/wp-content/uploads...1/SNV13596.jpg was superpole inducing volts
    http://rgey.de/wp/wp-content/uploads...1/SNV13599.jpg was standard mag config. inducing volts
    Hi all!
    People volts doesn't matter at all, what matter for me is how much current i spent for getting a lot of impulses.
    MrRonsen which transistor do you use in the circuit , i highly recommend to use MJL21193 transistor only.
    I would like to see the oscilloscope picture where system is running.
    the MJL 21193 is the wrong number you probably meant MJl21194....
    1,513
    Hi Tom C ,
    How does it matter? MJL21193 is PNP so you Switch at the Positive end of the Inductor, instead of the Negative end, had it been MJL21194 (NPN).....
    and yes Radiant switching at the Positive side does matter, especially to the device safety.. too High-Voltage and even the Neon bulb will not save the device..
    I Suggest some trials on using both to study the difference..it will be evident from the protection front..
    Sorry guys, yes its MJL21194! transistor.
    always switch on the negative when you can.
