Bedini RPX Sideband Generator
2019 ESTC ALL SEATS SOLD OUT!
PRE-REGISTER FOR THE
2020 ENERGY CONFERENCE
Monero XMR
Page 6 of 14 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 131
Thread: SSG Where the rubber hits the road
  1. #51
    You're right Guy - sorry Allen, I claim age and lack of sleep :-)
    Guy... coil... :-) pay no attention to the man behind the curtain. I need to rewind that coil to copy you again as is, it only has 3volts! need the C shape.
    Got the 8-TGB all plugged in now. Pushing toyota bat to 16 volts @ 573+/-mA, nice! I'm still at two spikes per magnet pass, need to re-adjust the coil further away. Also, the amp draw bumps around a bit. need to double check magnet spacing and/or break out the old "gauss meter" a-la yahoo group. and find the bad boy magnet - put him on the bench and put in a team player.
    Kind Regards,
    Patrick A.
    Quote Originally Posted by guyzzemf View Post
    we both herd clicking it was Allen R that called it [ a lose magnet] good call
    guy
    what going on with the flat air coil ,i see it going to a bread board?????????
  2. #52
    That was it, got it down to one spike/magnet. I just had to pull the coil away from the wheel a tiny bit...
    I'm going to see if I can get it to 16.5V then I'll take it down to 12.5 overnight and start out fresh in the AM. This battery might actually be a very good candidate for many experiments. I'll put it through a few runs before deciding to purchase the garden bat.
    Now, any suggestions on quick-n-dirty measure of IN vs OUT? Anyone?
    Kind Regards,
  3. #53
    Hi Patrick , everyone. Thanks. Totally jealousy over the straight and true wheel you have there. the wood wheel looks good. I suggest cutting the wood to fit the inner diameter of the wheel and so it has to press in. Lie it down on a known flat surface then use screws to secur it. Perhaps that will help true it easier.
    Did I calculate 71ma amp draw on the input? Is that normally where you run your input at? Just curious as I run mine at 120 and 220~ma there are two very prominant spots there on my wheel. Sounds lime I get the new wheel whipped up. My wheel is somewhere between junkpile and not nearly close enoufh to the smooth one you show later. This new one must be lest redneck engineer and more scotty engineer. Im getting excited to see the big eight running!
    Thanks to everyone. If Im not on for a bit it doesnt mean I dont see the posts. Ihave something I would like to see you try later when you get a chance. It has to do with backpopping through a gen coil back the run battery. I guess you could do it to a second battery. The gen coil will be placed in a position around the wheel so when the backpop event happenes the wheel gets a boost from the extra coil and the recieving battery still gets the charge. I have an old video that shows this being done and the effect is interesting. You see way higher voltages. I was using a dump switch i made that the turning wheel activated during motor off time. That setup didnt seem to take away from recover. It did add high voltage that ran all through the circuit plus it increased rotor speed. I will place it back on youtube and give you access to it if and when you might be interested. I do not want to distract you.
    al
    Quote Originally Posted by min2oly View Post
    Kind Regards,
  4. #54
    Senior Member John_Koorn's Avatar
    Join Date
    Jul 2012
    Location
    Melbourne, Australia
    Posts
    1,077
    Kind Regards,
    Hey Patrick,
    I intended to write up a long explanation of a quick way to measure COP, but hey you know how life gets in the way
    Anyway, the short version is that it's based on JB's method and goes something like this:
    1. Charge battery up to 15.3v and note draw current from primary with analog meter.
    2. Discharge secondary battery for 1 hour at the same rate as primary draw from step 1. Helps if you have a CBA unit or similar so you can dial in the draw current.
    3. Recharge secondary again to 15.3v. Note minutes taken to recharge.
    To calculate COP, divide 60 by minutes from step 3 for the electrical COP.
    For the total COP add the mechanical energy from the wheel as well.
    let me know how it works out for you.
    Edit: Make sure your primary battery is fully charged before starting.
  5. #55
    Friend if you happen to have in your possession a hydrometer for checking batteries I highly recommend that you check the specific gravity of the electrolytes in each cell of that battery. I think 12.5 sp. g. would be a good minimum limit.
  6. #56
    Hi Allen,
    I have to say, I can do all the justification of a wobble wheel still getting 1:1 and I can tune it just fine blah blah blah... This straight wheel makes all the difference in being able to tune EASILY.
    Any "distraction" someone brings up in this thread PALES in comparison to the distractions going on in my own head 24/7.
    I am interested in your dump switch and timing mechanism. Post it whenever it's convenient for you - LMK. I can take good notes for when I give it a go here.
    Thanks!
    Patrick A.
    Quote Originally Posted by Allen R. View Post
    al
  7. #57
    Hydrometer is a very good idea to check on each individual cell:
    this is a good quick read to have bookmarked:
    http://support.rollsbattery.com/supp...uring-specific
    "The following shows the approximate state of charge at various specific gravities at 77F / 25C.
    Charged Specific Gravity
    100% 1.265-1.275
    75% 1.225-1.235
    50% 1.190-1.200
    25% 1.155-1.165
    0% 1.120-1.130"
    Thanks for bringing that up...
    Quote Originally Posted by Quigon10101 View Post
  8. #58
    Thanks! this beats a complete run down/discharge, now Patrick can get some sleep
    What are your thoughts about leaving the amp meter inline for the whole hour? I ask because my draw increases when I shunt the meter. And/or what are your thoughts about using a clamp meter to mark the draw. I don't have one, just some of the ideas crawling around my head...
    Thanks again,
    Patrick A.
    Quote Originally Posted by John_Koorn View Post
    Hey Patrick,
  9. #59
    Something to watch w/ that afternoon Sandwich...
    I think it was Steven Cerovec?
    Anyway, one of the reasons I keep coming back to these forums is because there are always so many good people w/ great ideas and willing to share. It keeps me motivated.
    Kind Regards to all,
    Patrick A.
  10. #60
    steven crogan??? that is how i ck a coil strength mine has a weak spring in it
    measuring input has allways been a hard thing to be sure of ,i use a many different ways we all know and if thay are close to each other
    its good i think dad hav did a vid to show a very good way
    https://www.youtube.com/watch?v=9YeF...3lTJIrHm5FLLPA
Posting Permissions
  • You may not post replies
  • You may not edit your posts
