SSG Where the rubber hits the road
  • The Spike
    This always stuck with me regarding the Energy:
    • man... I miss Him. we used to do midnight runs to Jack in the box for tacos and talk about this. what a genius he was.... He was our living breathing Tesla. they will be mentioned in the same breath in the future.
        Simplicity that he defined!!!
        • As anyone who has watched my vids knows I've been working with reeds since the beginning. I'm always looking for ways to increase reliability and manipulate the "ON" time... the amount of time the reed connects and allows the transistor to be turned on. One can use a magnet in close proximity to the reed which will force it to close and open quickly as well as kind of shorten the ON time, it's very touchy however. John used 2 side by side magnets per switch on the Zero force motor to manipulate the reed further... Anyway, I've been doing this reliably for the last few months and thought I'd share:
Name:	Patricks VENN Reed Switch.jpg
          The VENN Reed Switch
          I've used this with my bike wheel (no timing wheel just the big N8's) to get the ON time down to a very small window - further increasing efficiency. Poof - "Shaka, when the walls fell."
          I thought it might help with the Zero Force but did not want to clutter that thread with a possible distraction...
          • Very clever Patrick
              [ATTACH=CONFIG]5606[/ATTACH]
              Great work Patrick. I might have to give this a try on my reed that switches my SSR.
              Thanks for sharing!
              • That's great, then you can also use the spacing between reeds to modulate On time. If I got my Forrest Mims intro to circuits right, then you've got an "AND" logic gate there.
                • Patrick,
                  I installed your switch method on my machine and it works great! Anyone using reeds should know about this, you have really let a great one loose here my friend. Thank you.
                  Here is a very short video showing it on my machine. I am not running in the video but rather showing how the switch improved my timing.
                  https://1drv.ms/v/s!AmzmftzD-V0mhwFH2D62ltLtBgBj
                  • Could someone please draw out the schematic that would allow one to replace the trigger circuit on the original sg with patrick's dual reed switch idea.
                    Thank you in advance.
                    • Originally posted by Brian McNece View Post
                      Hi Brian,
                      it can be as simple as this one I drew up here
                      if you start getting into multi-filer and multi coil and you still need a diagram, well.....
                      KR - Patrick
                        Patrick,
                        Very cool :-)
