Results 1 to 10 of 15
Thread: Which Solar Tracker V?
    Feb 2014
    160
    I will be purchasing a Solar Tracker V with capacity to run my home. I live about 1 hour south of Melbourne in Australia on the Mornington Peninsula and should be able to get sunlight on my panels almost all day (weather permitting) with the exception of the early morning due to some trees.
    My understanding is a Solar Tracker V will power the load and keep the batteries topped up. The batteries are only used if the ST is not able to power the load.
    Based on this, it seems logical to get as much high power consumption work done during the daylight hours such as running washing machines, dishwashers, electric ovens (but avoid doing them at the same time). and purchase an ST large enough to support the maximum load that one might expect these devices or combination thereof to draw. The hungriest device is the oven at 2856 Watts, on average is used 1 hour per day.
    Questions:
    • If the ST cannot power all the load does it continue to power as much as it can and lean on the batteries to provide the remainder, or does it hand off all the work to the batteries?
    • Maximum daily usage for my home should be 20kWh but I hope to reduce this even further as I make my home more energy efficient. So what would be the minimum size Solar Tracker presuming off grid usage and usage as per previous point?
    • Is it worthwhile running 2 battery banks or is one bank ok with a larger ST?
    Obviously weather introducues a variable.
    I am a beginner so I'm sure I am overlookig some obvious things. So lets expand from here so I don't make this first post to large
    1,456
    Questions:
    The 160A 12v or 24v is what you need if you have up to 2250 watts max if you have a 12v array or about 4500 watts if you have a 24v array.
    If you have more solar, use more than one Solar Tracker 5.
    Yes, provides what it can and uses batteries as last resort. It doesn't hand off all work to batteries unless there is no solar input.
    One bank of batteries is fine.
    This is the Solar Tracker to get - the S160A 12 or 24v unit: http://teslachargers.com/solartrackeriii.html#solar12
    Feb 2014
    160
    Can a 12V Solar Tracker be connected to a 24V solar panel? I will have my 10A12 Solar Tracker soon and may be able to pick up a second hand panel for testing with the following specs:
    Open Circuit Voltage: 37.32V
    Maximum Power Voltage: 29.79V
    Short Circuit Current: 8.9A
    Maximum Power Current: 8.23A
    Max Output Power Under STC: 250W
    Model: Topsola TSM60-156P
    No the rated input is set for the control circuitry (voltage) and number of panels (amps) . you will blow up your tracker.
    Feb 2014
    160
    Thanks Tom,
    P.S. Perhaps you could put the specs for the Solar Trackers on teslagenx.com?
    Sure we can do that, other than amps and voltage what info are you concerned with? if you are concerend with converting amps to watts, here is a fun website for caclulating a few things!!
    http://www.rapidtables.com/calc/elec...Calculator.htm
    and here is a worksheet for calculating daily loads
    http://www.wholesalesolar.com/StartH...applianceTable
    or here
    http://www.threeactionsproject.org/A...rgy-Budget.php
    100 year batteries
    http://ironedison.com/store
    Feb 2014
    160
    I was searching online for variations of "Use 24V solar panels with 12V charge controller" and discovered you can get MPPT controllers that will take input from 24V panels and output 12V. But the Solar Tracker is different, hence the question.
    I found PDF's with the Maximum INPUTS from the Solar Panel for the 10A12 on teslachargers.com website after your response. If I knew it was 22V then even though I'm a newb I could figure it wouldn't work, figured other teslagenx.com customers might have the same query
    Thanks for the links!
    yes an mppt controller may be built with a step down transformer inside, there are lots of variations of charge controllers out there. let us know if there is anything else you need.
    Hi Tom ,
    looking to buy a solar tracker 3amp 12v which on the Teslagenx site you call an rv and marine i have a small 40 watt solar panel that i want to use with a solar tracker 5 to rejuvinate batts with and and also charge my front end batts for my sg and as a peliminary to going bigger so i can get exp with the hardware etc,
    can you tell me approx when you can ship if i ordered this immediately.....
    i have another q also .....has jb thought about doing a line of pure sine or really clean inverters... for delicate circuts like heat pumps computers etc....im just about to put 2 heat pumps in and have asked quite a few electricians and installers of heat pumps and havent been able to get a definate answer for anyone if its totally safe ....thought u may be able to shed some light on my q,s ..thanx in advance .....Pat M
    Patrikas,
    I do not know what energenx has in stock, but I can let you know tomorrow. send an email to sales@teslagenx.com also, if you have bad batteries the tracker 5 will not restore them, it is designed to keep good batteries new, it is pure DC designed to cutoff at the correct voltage. if you need to restore you should use a monopole.
    I do not know if energenx has anything on the design table for inverters. you need to contact the manufacturer of your heat pump and ask them if it can run off a modified sine wave inverter, or if they have DC heatpumps, then there is no loss doing the conversion. http://www.hotspotenergy.com/solar-air-conditioner/
    pure sine wave inverters are really expensive.... I have run pc computers off of modified sinewave inverters no problem, this is just personal experience no guarantees here.
    http://www.off-grid.net/forums/topic...puters/page/2/
