Results 1 to 6 of 6
Thread: SG : Doubling the magnets (stacking up), would that improve the charge efficiency ?
    Hi, I have read some material from a john54, happy sharer of his experiences albeit not SG (cactus and kitty hawk Bedini patent derived machines).
    If I recall well, he argues that Doubling the magnets (stacking up) would improve the spike strengh.
    Hence. Would that improve the charge speed rate, efficiency ?
    I would be thinking of trying that, but I don't want to spend on magnets for nothing. After all, we're here to save energy, not a consumer mass market , right ?
    Thanks a lot in advance.
    No, save your money. The magnets on the rotor are only there as a trigger. The spike is coming from the collapsing magnetic field of the coil.
    Hi Bung-ee,
    one of my early builds was a "Kaktus express" but the results were disappointing. The wires of the coils were too short and too thick, but the machine developed a good
    accelleration of the rotor without increasing the output (charging rate) and i decided to lower the speed using a pair of generator coils connected to a FWBR and another
    battery. This additional output depends on the strength of the magnets. So this is the point where double stacked magnets are better than single. A doubled magnetic flux will
    result in a doubled AC voltage on the same load and that means four times of the produced power. But this is theoretical, because double stacked magnets do not double the
    magnetic flux (as far as I figured out) in reality.
    just for your information, have fun
    Jun 2014
    Thessaloniki Greece
    11
    But won't the collapsing magnetic field be greater if the magnet is stronger?
    Quote Originally Posted by hobbyrobotik View Post
    Hi Bung-ee,
    Hi hobbyrobotik,
    I feel we're on the same road (again).
    I have not made much progress with my SG, it's still a 12V, 0.200A Fan that recharges or rejuvenates *somehow* because I have destroyed AA batteries doing so. For now my results are mitigated, but the AA battery failures may be inherent to the design ?
    I am working on other projects and would like to chain resistors instead of the battery, andd see if with the heat produced and the fan action, I could extract free heat for still 2 Watts that my bedini fan is producing.
