Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Where is the Advanced (Third) book on building the Bedini SSG
    1,456
    Quote Originally Posted by rdvideo View Post
    Attachment 3440Attachment 3441Attachment 3442Attachment 3443 Great. I like what I have been seeing and reading and look forward to the third book because I have tried adding a rotor and stator to my SSG and it right now easily gives out 6 v DC at low RPM's because of the Lenz effect, something that I missed and maybe I have the magnets too close to the stator. I am using 10 Neo magnets (2" x 1/4" round) and 15 coils (18 gauge) on the stator wired for 3-phase. I like experimenting to see what happens that I think what I started will work some day with more RPM's to generate more power to use else where. You do not know if it will work if you don't try. My house is all electric and my electric rate starting June 1st will increase by 38%. What a rip off that is since ComEd charges the most in my area and there is nothing you can do about the increase. I like to find the cheapest way to go off grid because I have a small river that cuts my backyard in half and finding ways of using it for extra power creating using an old washing machine. And yes, I know what can be done with solar energy because of your great free eBook clarifying the myths out there. Now I have something to tell my nephew that took a class on setting up a solar system the wrong way. Keep up the good work that you, Peter and John have been doing.
    I agree with Guy about the spacing of your magnets around the wheel are too close together. If you took a couple out and re-spaced them all, it should run faster. I'd use the same number as specified in the first SG book. It is kind of counter intuitive but with a little more space, you will actually get a faster rpm. If found this out way back with the small roller skate wheel I did. With 2 identical wheels, one had 4 magnets all the way around and one had 3... the one with 3 went significantly faster so you do have to give it some breathing room.
    Yes the dead zone, there has to be a zone with no magnetism at all. So you get the maximum difference between magnesium and no magnesium. The rate of change is most as possible.
    If the magnetic cores (from the coils) are blades rather than circle shape, then this makes it better still. I am taking from experiments here.
    So if you take the core out from a coil, and spread it out to be the same width of the magnet.
    This increases the magnetic attraction to the core, because we have increased the surface area between the magnet and the core.
    Thumbs up Thank you for all of your work on the third book.
    Quote Originally Posted by guyzzemf View Post
    Hi there to all. Thanks for your input. I had to stop working on my project when I got laid off from work and had to retire early from my job at Northrop Grumman. Now I've been working part time for a while now and saved up some cash to start my project again.
    The first thing is to thank everyone involved with the Advanced book and tells a lot, great job done. I work part time at soundsclassic.com in Rockford, IL and have the owner interested in Bedini's work too. I and Mark started in electronics about the same time John did and also was interested in audio electronics. One buy of audio equipment from a closing audio store was a Bedini power amp with one bad channel. This is a subject for another time since I need to find out what output transistors were used so I can replace the transistors that are shorted. There are no numbers on the transistors which is the same thing done at Northrop Grumman so nobody knows what the part is, but they put their own numbers on the part. Like to get this amp working again.
    Other than the audio side, after seeing the video of Peter with Beyond the Advanced book, I am interested in the Mini Beast specs shown too. I am going to complete the SSG according to the books using what equipment I already have to get back into the project and use the new knowledge I learned here about it.
    Thanks again for all of the information given about spacing the magnets and the books. Look forward to more information to help continue with my project.
    1,456
    John does still repair his old amps. Contact John thru here: http://energenx.com/company.html#contact
    The books are at http://bedinisg.com - the book specs show 7 power windings and 1 trigger, but on the same core, I believe you can fit 8 power windings and 1 trigger. Teslagenx has those coils pre-wound if needed.
    Let us know if you have any other questions.
