circuit to charge a battery
  • circuit to charge a battery
    would you help about bedini cirguit...
    I constructed one, but not charge the other batery... thanks very much
    thanks very much
    ralphfields
    Ralph,
    need a whole lot more info and pictures if you want help.
      http://www.youtube.com/watch?v=IkOEqPW0ASY
      Thanks very much, the link it's a video more the next information
      Coil hits the transistor 80 turns 26 gauge enamelled wire
      Primary Coil to the collector battery load 23 gauge enameled wire
      Neodymium Magnets 4 d 5 x 2.5 x 1.2 cm
      Connections on PCB as you can see in the video of 1.36 minutes
      Any other information with pleasure
      Thanks mr. Tom C
      Ralph
        Ralphfields thanks for sharing your work
        Use only Ferrite magnets
        No neodymium to strong for bedini charger
          Thanks mr. Tom C
          Ralph
          this is not going to be a good SG .
          1 use ceramics not neo
          2 need a lot more turns on your coil for the electromagnet to function
          Build it like JB has designed please you will be much happier.
          where did you buy the circuit board from?
            Thanks by your information i ll do the change recomended
            and i ll tell you the result
            How or which is the original circuit of JBedini,
            how many turns is the correct
            How much cost a complete information ?
            I live in the mountain and i need urgent a solution because
            i not have electricy where i live.
            My friend do the circuit board
            thanks very much
              thanks very much
                look here for all the components and the E-book on construction
                www.teslagenx.com
                  Bedini SSG schematic
                  1. How or which is the original circuit of JBedini...
                  2. how many turns is the correct
                  1. http://rpmgt.org/JoinBediniList.htm
                  2. Bifilar coil ~ 850 winds...
                  See the link for all the details, including videos
                    [ATTACH=CONFIG]3176[/ATTACH]
                    They are the old instructions, which are now incorrect and out of date.
                    The latest instruction, endorsed by John Bedini can be found here: http://teslagenx.com/digital.html
                      My friend build the circuit board
                        ralph, you need to secure the coil - not rubber bands.
                        is your friend selling the circuit boards?
                          I don´t , I´m going to ask to my friend.
                            I do not buy the circuit board, my friend do that!!
                            Today, I buy the complete intermediate handbook from Peter and Aaron,
                            We are going to build the option "The Capacitor Discharge using NPN Transistors",
                            and I have a questions.
                            It is the better option?
                            We use a horizontal aluminun bycicle rin, what will be the ceramic magnet size, for 800 wind coil?
