Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: Tesla Solar Tracker III
    Battery Chargers
    TESLA SOLAR TRACKER III
    12 & 24 VOLT SYSTEMS
    These 12V & 24V Tesla Solar Tracker III's are specifically designed for offline solar power systems. They are fully integrated solar charge controllers.
    Most charge controller and solar panel systems cannot even start charging the battery banks until there is direct bright sunlight on the solar panels.
    It is common for these Tesla Solar Tracker III's to start charging as soon as the sun comes up until the sun sets. Marginal light is the minimum requirement - so you can have battery charging all day long even under cloudy skies!
    This does not have to do with the solar panel, it has to do with the interaction between what the solar panel sees in relation to what the charge controller does with it.
    No other solar charge controller in the industry can compete with this game-changing technology built by John Bedini, the world's indisputable master of battery charging technology.
    Many solar system have to have their battery banks changed every 5-7 years because the conventional charge controllers do such an incredibly poor job at even getting the battery voltages up to where they like to be.
    Therefore, there is normally sulfation layer upon sulfation layer, which never quite gets removed with conventional charge controllers.
    The Tesla Solar Tracker III will deeply rejuvenate the battery bank when charging fully removing the sulfation layers and getting the batteries to a higher voltage, which keeps them in good shape.
    What does this mean?
    It means you will not have to change your battery banks as often, if ever, and this makes your ROI for your solar system simply make sense.
    • Simple common sense installation. Simply connect the input then connect the output - that's it!
    • Simple and easy accesible fuse.
    • Easy to read LED status indicates when the battery is being charged.
    • See owner’s manual for more details.
      GET YOU OWN ENERGENX TESLA SOLAR TRACKER III HERE: ENERGENX TESLA SOLAR TRACKER III
    I have purchased a 60amp solar tracker III,have two panels,will be buying more soon.I have a large inverter.
    So what batteries shall I buy.
    Do I get two banks of batteries one on charge the other on the inverter & what watts/amp hour should I get.
    Is there anyone out there who can help
    Montreal, Canada
    19
    TST3 1st few runs
    Here are some results charging 24V Bank of 6V Batteries accross TST3 24V 20Amp with one panel delivering approx 9amps in full sunlight.
    The batteries are:
    4-5Yrs. old, sitting in a shed for the past 2yrs.
    TC Trans Canada; they look to be like Trojan knock-offs
    6V - 210aH
    Resting Voltage 4.8 - 5.2V per Batt.
    The chart shows 3 discharge cycles with each one progressively getting better. The 3rd cycle shows 216aH before cutting off at 21V. Not bad for for 4yr. old sulfated batteries.
    I also started converting two of the BATT's to ALUM, early results put them around 140aH out of the gate with a basic 4:1 mix. I'll post results on the crystal batteries thread once i more data becomes available.
    D./
    What exactly are your intentions? Also what size inverter plus the info on your panels would help(Brands...model number(s),etc. for both the inverter and panels). What voltage is the Solar Tracker III model you have also?
    Quote Originally Posted by utopiandream View Post
    1,456
    If it is from Tesla Chargers, you can email Peter directly at the email on the banner at www.teslachargers.com
    He is extremely swamped right now with some deadlines so I'm not sure he'll be able to post here soon.
    1,456
    Quote Originally Posted by 888spo View Post
    Thanks for posting those results!
    Aaron murakami & John H
    I tried to buy a LLE from r-charge but they had no stock,so in the end just went for it & bought a 60amp tracker,I want to power my home,& can size the load to fit the avaliable power.
    I live in sunny Portugal.
    I have lived with solar so know the practicalities.
    So if I put the max in.And if the inverter can handle the load.
    Batteries,lead acid?with normal solar you always leave 50% in & have excess power for cloudy days.But Im guessing you need 1/3-1/4 of that with these systems.And do I get two banks of batteries one on charge the other on the inverter,how many amp hours.
    Thanks for your help,sorry about all the stupid questions.
    Calvin
    I don't understand why the price of 24A12 is almost $2000 and the price of S20A12 is $500 when the amperage is almost the same? I understand the convenience of 24 hour charging for a plug-in unit 24A12 versus a 12 hour charging with a solar panel for an S20A12. Is there any difference how well one or the other works/rejuvenates when compared to each other? Why such a dramatic difference of $1300 between the two devices?
    Hi all,
    Just doing a feeler... Would there be any interest in a 48 volt Tesla Solar Tracker? If the answer is yes please reply here and let it be known.
    Thank you,
    Dave Wing
    1,456
    Quote Originally Posted by tesla View Post
    The 24A12 is not a solar unit and comes with its own power supply.
