Copper coated welding rods
  • Copper coated welding rods
    I am getting ready to purchase the welding rods...found the r60 1/16th...but not sure if they are copper coated?
    Weldingsupply.com / OKI-Bering (Brands) / 60-116-36
    This look right?
    Hi Branch. I found 1.2mm or the thinner 0.8mm mig wire to be OK in my experiments. This is the same steel content as the welding wire and I use it when using the oxy acetylene . It is way cheaper than the recommended welding rods. If you don't want to buy a 15Kg roll, find someone around you that does mig welding. You will need 300 pieces of 0.8mm or 200 pieces of 1.2mm wire to fill each coil core at 3/4 inch diameter.
    Clyde James
      Thanks Clyde..but I'm trying to build it to exact JB specs.
        This might help to know the mixed of the R60 and others Click image for larger version
