Took a dead 10 yr old 160 cca John Deer lawn tractor battery topped it with distilled water and cycled it on my sg 30+ times several months ago, thought I would wake it. It would take the charge, and "leak" back down to 7 volts. 2 bad cells? Sure. I gave up and put it on the shelf. Last weekend, since it is smaller, i figured I would practice making an alum with it. Charged it with conventional charger to 15 volts, drained, and rinsed it 4x with distilled. Dried it out for a couple days. Heated up some distilled water and mixed up some alum. Poured it in and charged it first time with conventional dc to 13.5 volts. Drew 1 amp for 4 hours down to 10.8 and it bounced back to 11.2 volts and stayed over the weekend. Battery would be a 8 ah equivelent. Now charging with sg mode 1, seems to be hungry for a charge as it is taking a bit to charge it up. Very promising and exciting. Aln
