Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Comparator with 10 coiler
    Hi John Koorn
    This is offtopic but i want you to ask if you have experience with this Patent.
    http://www.google.co.in/patents/US20020097013
    Thank you
    Hi forelle, I've read the patent many times but have not built the exact model depicted in the patent.
    It's not totally off-topic from this thread as it's very similar to the Bedini Monopole SG.
    gandyman, yes I see what you are saying.
    My recommendation when experimenting with cap pulsers on a large machine such as a 10 coiler would be to take it slow and start with just the master coil.
    The neons will flash when the capacitor can't take anymore charge, so you have to make sure the cap pulser (or comparator) is set to discharge the cap before it fills up.
    Once you have it working and tuned properly with one coil you can add additional coils one at a time.
    Indeed John
    BTW @forelle, this patent has more to do with the mechanical layout, the electronic switch is the same as the window motor
    this is a great quote from the patent. remember the patent examiner or special master must agree with the text and drawings of the patent AND see a working model performing the functions outlined. in essence the patent examiner agrees with the text of tha patent and in this case the novel design of the functioning unit allowed JB to get a patent....
    [0019] A problem relates to how back EMF energy can be obtained from a circuit's external environment for the specific task of reducing the back-drag EMF without the operator having to supply any input of that excess energy. In short, the ultimate challenge is to find a way to cause the system to: 1) become an open dissipative system, that is, a system receiving available excess energy from its environment, in other words, from an external source; and 2) use that available excess energy to reduce the drag-back EMF between stator and rotor poles as the rotor pole is leaving the stator pole. If this objective can be accomplished, the system will be removed from thermodynamic equilibrium. Instead, it will be converted to a system out-of-thermodynamic equilibrium. Such a system is not required to obey classical equilibrium thermodynamics.
    this is a tacit admission from the patent office that an open system does not violate the stated laws, and wherever you get your added energy from is o.k.
    1,473
    Hi John,
    Is this Cole-Switched version of the Bedini SG?
    Hi John,
    Hi Faraday,
    It's more like a permanent magnet stator version of the window Bedini-Cole window motor.
