Page 1 of 6 123 ... LastLast
Results 1 to 10 of 52
Thread: Snowman 8 Transistor SSG Build - Trigger Problems?
    Heart of Vermont
    347
    Hello to all!
    I recently completed the 8 transistor kit w/ coil and holder provided by Teslagenx. The kit was purchased middle of the summer and finally enough time was available to complete everything over Thanksgiving. The SSG Beginners book was used for all the relevant information along with a PC board pic provided by Teslagenx (manual not available earlier).
    The unit was mounted on a self designed wood system that can accommodate a number of wheel sizes for flexibility. So here are the details:
    Wheel size 26" nominal w/22.5" actual rim diameter
    21 magnets in kit
    8 wire #20awg along w/1 #23awg for trigger winding
    12 ohm trigger resistor
    Rest of electronic components supplied in kit
    2 12 volt Garden tractor batteries
    It was first fired up 11/29 and it definitely was off - did not sound right and transistor heat sinks were way too warm! Discovered that in an unfocused moment the primary battery connections had been inadvertently reversed. Yikes, corrected the problem immediately. Spun the wheel again and nothing happens. Ooops, started the tedious process of checking everything, all the connections; the works! Became sidetracked after checking everything into thinking that the board's transistors or other parts were damaged.
    So two days were wasted troubleshooting with no tangible results. A savvy friend offered to check the board's transistors etc. and board sent to him. Ordered another 8 transistor board kit from TX and received it 12/9. Put this new board together (using provided instruction set) and on 12/10 wired up all the components (using TX instructions) and voila! - Nada again. In the meantime the savvy friend sends an email detailing that there is nothing wrong with the original board. Transistors and diode etc all check out.
    It is obvious after checking the connections today that the trigger circuit is not firing for some reason. All the coil wires check out with continuity. Performing a straight short test to the primary battery with each wire individually energizes the coil - all good! Same with the trigger wire. The gap between the coil and magnets has been varied from 1/16" to 1/2" - no luck here either.
    So we have two boards here that display the same no run characteristics. Both pointing towards the trigger circuit not functioning as required. Not a coincidence. Something is amiss here and it is probably either very simple or just plain dumb.
    An appeal to the masters of all things Bedini for help is in order. HELP!
    Hi Yaro,
    A couple of basic things to check.
    1. Ensure that the ends of all the coil wires have the enamel cleanly scraped off and "tinned" with solder to ensure good connections to the board terminals.
    2. Measure the DC resistance of the coil windings (not connected to board) - power windings should be ~3 ohms and trigger winding ~5 ohms.
    2. The trigger winding could be wired backwards, swap it around and try again.
    Heart of Vermont
    347
    Hi Yaro,
    John,
    Thanks for the response - well all those items have been done and checked. Resistance is about 1.7 ohms per individual coil wire and 3.4 ohms for the trigger wire.
    This may be a bit more complex than it first appears.
    please post a picture of your board connected to the coil and the batteries.
    you have used the welding rods with your coil?
    not only air coil?
    the long end of the welding rods is placed on outside/bottom.. not between coil and magnet wheel !
    this will suffer to low trigger voltage..
    here some of my steps, experiences with triggering..
    http://rgey.de/wp/?page_id=874
    Heart of Vermont
    347
    Been on travel for a couple of days. Thanks to John K, Tom C and MrRosen for their suggestions and links (excellent MrRosen, very helpful). I will post the pics on Sunday AM after the snowstorm cleanup is finished. This east coast storm looks strong - hey its full moon!
    Heart of Vermont
    347
    Snowman SSG Pics
    Enclosed are a couple of pics for that display the Snowman SSG 8 Transistor wiring arrangement and configuration. You will note that the primary battery cable is disconnected from the (+) terminal; you will also note that four of the coil wires are not connected to the board terminals
    1) Trigger wire start to Primary (-)
    2) Trigger wire end to Trigger terminal w/ resistor
    3) Primary Battery(+) connected to end of coil (8 wires)
    4) Primary Battery(-) TO BOARD AS MARKED
    5) Coil start wires to board terminals (8)
    6) Board output Charge (+) to Charge battery (+)
    7) Charge Battery(-) to Primary Battery(+)
    So all the above is according to the instructions in the Bedini Beginners Book and the Teslagenx literature.
    It does not appear that the trigger is working properly... Trigger wire through coil is 3.2 ohms, with the connecting wire to the trigger terminal for the coil end at 0.3 ohms. There does not appear to be an issue here. The coil gap (magnets to coil rods) is at about 1/8" ~ according to spec.
    The Primary Battery voltage at 12.66 volts which can be confirmed at the binding posts for the coil wires. This battery was charged two weeks ago with 10 A 12. There are no apparent shorts/opens in the wiring or the circuitry. Rocking the wheel back and forth over the core will produce ~ +/- 40 mV in the trigger wire. Sorry, there is no scope available at present. There is a simple solution for this, however it is not readily apparent to this novice.
    Any Thoughts?
    Heart of Vermont
    347
    Ta Da,
    Tightened all the posts and connections, again, separated the trigger and Primary (-) terminals; and then labeled everything so that it was intelligible to me and anyone else. Took pictures for documentation; I fired it up and checked the error on neons by removing a terminal on the charge side - they flashed (finally).
    OK, Next step - where was the fault? Obviously the labels made this work... I really do not know the cause, suspect that that connections were not cranked down enough? I tightened all connects to the breaking point. I think the trip to NYC and the partying helped to clear the brain and other cognitive faculties.
    Anyway it is running and doing its thing, why the mystery and non start? I have no answer at this time.
    May the force be with you,
    Hi Yaro,
    Glad to hear you got it going. When you say "separated the trigger and Primary (-) terminals", how did you do that?
    I would lose the clip lead wire to the trigger terminal - many a fault has been caused by cheap clip leads
    Heart of Vermont
    347
    Hi John,
    I cleaned up the wiring on the board by eliminating all clips, crimping, again, the wire terminals and cranking down all the screw posts for the wires. The (-)Primary was placed on one screw post and the trigger start wire placed on the other screw post beside it. The one remaining clip to the trigger coil end terminal was attached directly to the trigger wire - the clip and trigger wire were soldered together!
    The wheel has new bearings in it, not broken in, so they are still a bit tight. Initially, the wheel required good rpm with the coil gap being just under 1/4", however the circuitry engaged and you could hear the smooth rumble right away.
    I believe my startup issues were directly related primarily to the wiring connections and perhaps, the start up speed/tight bearings. I will do more post mortem work on this later. All in all, this was a great puzzle to work out and the forum support muchly appreciated.
    This initial aspect of the SSG project is done, now on to the tuning!
    Happy Holidays,
