Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 52
Thread: Snowman 8 Transistor SSG Build - Trigger Problems?
    Heart of Vermont
    313
    Cool SSG RPM Measurement - A Simple Solution
    Tuning the SSG build requires RPM measurement in order to adjust the coil gap and other things. Simple - ugh! There are various ways of doing this and many are pricey and highly complex. Many experimenters have resorted to using a bicycle speedometer and a spreadsheet to do all the calculations to get the miles per hour converted back to RPM. What a pain in the left nostril!
    So let us take a look at this and try to simplify the process. The Snowman went to Walmart (KMart or another is OK) and picked up a Bell 100 speedo for $12.95, tore the package apart, carefully, and the read the instructions. Yow- measure this, calculate that and the covert everything to millimeters. Sheesh - lets simplify this process with some basic algebra:
    MPH= 3.1416*2R*RPM*60/5280; where R= wheel radius, RPM = revolutions per minute, 60 minutes in an hour, 5280 feet in a mile
    MPH=0.0357*2R*RPM; by definition 2R= wheel diameter D.
    MPH= 0.0357*D* RPM; Simple algebra shows that
    RPM= 28.01*MPH/D; Way better - lets modify this so RPM can be read directly off the speed display by simply multiplying the MPH by 10. To accomplish this we select D to equal 2.801 feet -OK?
    RPM= 28.01* MPH/2.801
    RPM= 10*MPH Great! Now you to insert the bicycle wheel circumference value in millimeters into the Bell 100 computer.
    Circumference = 3.1416*2.801 feet
    Circumference = 8.800 feet or 105.6 inches; Conversion to millimeters by multiplying 105.6 by 25.4mm/inch
    Converted to mm =2682 mm
    Insert this value into the Bell computer and fire the puppy up. Read the MPH on the readout and multiply by 10. This the RPM read!
    The Snowman has attached a crude cob job to show that it does work - used a hex pencil (flat faces), zip ties, Electrical tape and rubber bands. This will be cleaned up to look pretty and semi professional (hah!). Perhaps someone has done it this way before, anyway, worthwhile to repeat it.
    Cheap, Simple and Accurate for the first time builder!
    Happy Christmas,
    I appreciate your spirit of helping and effort.
    Most people just use one of these however.
    http://www.ebay.com/itm/Digital-Lase...item20dcdff504
    Heart of Vermont
    313
    BobZ,
    You are right - that will work well also. Thanks for the pointer! Anyway the calc exercise was a bit of a diversion...
    Heart of Vermont
    313
    Cool Impact of Soldering
    Happy Santa to all,
    So the last suggestion was to solder all the critical joints. Good enough! Prior to soldering of the joints we did a run on the Snowman 8 trans SSG as configured and came up with 232 RPM as measured by the Bell 100 system outlined in the previous send. The critical terminations were: 1) coil windings, 2) Trigger terminals and connections, 3) Primary(-) and Charge (+). All the 10-32 steel bolts/screws were replaced with brass. None of the screw terminals were soldered to the board.
    These changes resulted in an improvement of approximately 8 to 9 Rpm or nearly 4% to 241 RPM for the config as described above. Nothing else was changed or modified. OK.
    For reference purpose the Primary battery was at 12.7 volts at the start of the above run. The coil gap remained at ~1/8". No change here.
    Again, for reference purposes the RPM w/ the trigger resistor was 241, while w/o the trigger resistor 237 RPM. Not much impact here...
    Please note that this system is stock, bearings have not been cleaned up yada! yada!
    There were no measurements on amperage from Primary to board. This will come later when the appropriate methodology is applied. So, this is a good start!
    The sole intent of this thread is to document this build and the subsequent results. Your experience may differ.
    Interesting note - when the nearby CFL lighting was moved there was a very minor change in the RPM, +1 or +2, then settled back to 241 - interesting!
    Best to all for the holidays,
    Snowman
    Heart of Vermont
    313
    Impact of Aligning Wheel Magnets and Coil
    The alignment of the wheel magnets to the centerline of the coil rods was tweaked yesterday. The magnets on the wheel are fairly closely centered on the rim, close inspection revealed that the centers of the wheel magnets were off approximately 1/4" or so from the center of the coil rods. This was corrected and the SSG restarted again. The steady state RPM of the SSG gained approximately 12 RPM to 253 RPM from the previous config.
    So, the SSG is a sensitive beast and small changes can impact the speed of rotation. Two, seemingly, minor changes have improved speed by about 10%.
    Later,
    Heart of Vermont
    313
    Cool Restart of SSG Projest after Holiday Hiatus
    Well we are done with the Holidays and its time to refocus back to more serious matters such as the idle Snowman 8 transistor SSG.
    Effort has continued to establish some baseline data with the operation and performance of the Snowman SSG in its current unrefined state. Meaning that the wheel bearings have not been cleaned of the packed-in grease, the batteries are out of my mowing tractors and one is not quite prime time, the discharge method for the charge battery is way low tech - a 6 watt automotive bulb sucking up 0.475 to 0.48 amps. A simplified way to learn the base characteristics of this cool machine while it is in the untuned raw state.
    So to recap the machine:
    Teslagenx 8 transistor board and coil kit - nice!
    22.3" Outside diameter Alloy wheel - bearings stock and greased packed for now.
    21 Teslagenx magnets; spacing between magnets ~ 2.6".
    Current Coil to magnet gap of 1/8" - magnet to plywood coil mount (welding rods protrude through base of this mount).
    Current RPM - a stable 245, can be pushed to 250 with lots of patience.
    1.35 amp draw from Primary battery.
    Takes about 2.5 charges of the Primary to boost Charge battery to 15.3 volts from 12.2 volt draw down level. An Energenx 2A12, sometimes a 10A12 is used to pump up the Primary.
    Takes 10 to 10.5 hrs to discharge Charge battery to 12.2 volts - patience!
    Meters used are a BK 389 Test Bench, Extech 430 and for amps a Sears Pro 73756 clamp on.
    Batteries are lawn garden type NAPA 8224 N and a very similar Husqvarna; both with 230 cca @ 0 degrees F. No way are these 20 amp hr batteries IMHO...
    So the above is the baseline that we will use for comparison purposes to assess the impact of changes and modifications as progress is made to achieve the holy grail of a COP>1 for this machine. Truly an adventure and more to come on this thread!
    Please bear in mind a quote from a now obscure manual - "Some assembly required; batteries not included!"
    Regards,
    Snowman
    Heart of Vermont
    313
    Thumbs up Degreased Wheel Bearings and Removed Seals - Results
    Finally got to working on the new bike wheel bearings after being reminded of this step by a number of people. So we disassembled the wheel, removed the seals and flushed out the bearings. Checked the cleaned out bearings by turning by hand, ugly! A lot of rough spots, anyway put a couple of drops of whatever super lube that was on hand and presto way better. These are new bearings installed in the wheel about three weeks ago - not really broken in as yet. A free wheel test to be done later...
    Put the wheel back on the wheel mount, hooked up the power and gave it a twirl. Well sir, the machine responded by noticeably accelerating much more rapidly and increasing rotational speed to 274 RPM. About a 12% gain over the previous 245 RPM with no other mods. This works...
    So let's check the output amperage from the Primary. Whoa! Preliminary read was 1.56 amps, this was confirmed an hour later w/ a similar read. A gain over the pre-mod run of 1.35 amps. So this modification does result in an increase in power consumption along with the RPM gain.
    So what happens to the charging amps? Well the clamp-on reads about 0.74 amps, however we will let this go for the time being and restart another run to see the impact on charging time to 15.3 volts on the charge battery from the previous baseline of 2 to 2.5 charges on the Primary. More later on this aspect.
    So the results from the bearing degreasing and seal removal leads to an improvement in RPM and charge amperage. Enough for now!
    Best to all,
    Snowman
    Heart of Vermont
    313
    Freewheel Test
    Well time to do the freewheel test - a pain to disassemble the mounting rig, but there was another 8 trans board (spare and another story) to run. It was anticipated that there would be a very marked increase in Freewheel time based on the improvement in the RPM. Not to be!
    The freewheel time increased from 75 sec. to 120 sec. about a 60% improvement. Not very impressive despite the gains noted in the prior post, WE need 480 secs. Ugh!
    It seems necessary to run this wheel for a while to smooth out all the minute metal imperfections in the bearings and see where this plays out.
    Plan B is to get another wheel from the supplier Tom C. recommends. We learn by our mistakes!
    The discharge of the Charge battery (NAPA 8224N) is accomplished (for the time being - thanks NAPA) with a 6+ watt auto marker/direction bulb (measured at about 0.48 amps with two meters). Will consider eating the West Mountain package in the future for the sake of discharge data accuracy. The batteries are rated at 230 CCA @ 0 F. The amount of time required to discharge at The C20 rate (20 hrs) for these batteries will be lengthy, like more than 10 hours... Not really sure at this time what the real amp hr capacity is for these batteries. Does anyone know? We can perhaps estimate the capacity at 10 to 15 amp hrs after conditioning. Time will tell.
    There is a question as to why both batteries in the SSG have to be similar... Simpler to put in a larger battery on the primary side and monitor its discharge amperage. Why muck around with continual charges of the primary? You can't switch the batteries around as per recommendation anyway - so what is the point besides simplicity and cost?
    Irrespective of the questions, this SSG project still remains as very interesting. The next goal is to establish a control performance test with a standard charger for comparison COP purposes. More on this later as matters progress.
    Started to condition another battery for the actual testing when initiated.
    How did we get into this interesting madness?
    it will be 20 hrs...... if you discharge in 10 HRS that is C10.....
    sorry just wanted to be clear on that.
    the goal is 1 to 1 charging. having the same batteries front and back insures your are doing identical work. its all about balance in the system.
    Heart of Vermont
    313
    Tom,
    As usual you are correct, the C20 time is based on 20 hours of discharge at a given rate for a particular battery size and is dependent on its level of conditioning. No question, however it is a matter of procedure and fact that a properly conditioned battery will gain capacity as the number of SSG runs and associated discharges increases. Therefore, in the initial discharge runs the battery may be well below its ultimate capacity and it may take the recommended 20 run minimum to reach this ultimate 1:1 capacity. That is understood and the goal is understood.
    One of the questions for a beginner (8 trans build or whatever) is, "what is the correct battery size and what is the recommended C20 rate?" Knowing that the NAPA batteries are for starting purposes only, the C20 rate was selected conservatively as an ~ 0.50 amp draw (10 amp hr) and 12.2 volt low threshold. For beginners on a limited budget the NAPA 6 watt bulb fits the bill. Is this the correct draw? Well, that will be determined from the conditioning process as outlined by John K and yourself. Let's see how this plays out!
    Thank you all for your patience in answering the tedious questions.
