Page 11 of 40 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 395
Thread: The SG Radiant Oscillator
  1. #101
    Thank you for the clarification I sure will check it all out with the scop .
    Ehsan
  2. #102
    Hi John,
    Want to check circuit hookup with the 2 trasistors.
    Trifiler coil?
    Don't see the emitter to collector diode ala US7990110 B2
    bro d
  3. #103
    Mr. Bedini
    1. What kind of POTTING COMPOUND do you use?
    2. How much is it?
    3. were do you buy it?
    Thank You, Have a great night.
    Geoffrey
  4. #104
    1,529
    Hi John!
    A post to Mr. Bedini from Geoffrey sr Miller about an EXP. on a dry cell battery.
    Hi Mr. Bedini
    My name is Geoffrey miller this is my first post ever on any forum, I have followed your work since the late 70's.
    and all the other people in the "Free Energy Field." I have my owen lab that I work out of. I have built your sg units and they work Great! From little to big ones. I also have your first books from the 1980's.
    The reason for the post is, can you provide a circuit diagram and parts list of the post from 2005 consering your EXP. of,
    "Experiment with the one wire system that Tesla developed."
    I have done radiant EXP's of Tesla for a very long time. with 12 foot coils.
    I would like to run your EXP. on a small to a big scale.
    IF you want to send the info off line here is my e-mail nt@energybat.com
    Your work is Fantastic!
    Thank You and have a Great Day!
    Geoffrey sr Miller
    Wed Mar 30, 2005 9:18 pm
    My Experiments,
    As a continuation of my experiment with the one wire system that Tesla developed.
    I said that it sucked all the charge and electrons out of the battery with false indications. Here is what happened, I used the oscillator converted from a SG circuit forced oscillation, the current at the oscillator never going over 600Ma, the frequency was at 20Khz. The one wire transmission went to two bridge rectifiers and a capacitor. I used the inverted circuit with an SCR and a neon bulb to trigger the signal to the battery. The signal of the oscillator is as seen on my home pages, Iím holding the oscillator along with a scope shot of the signal.
    I connected everything up as i have always done. The meters indicated that the battery was charging, but when I got near the meter the meter shut down and the digital display started to flash. If i put a light in series with the battery charging wire it indicated current in the wire as the light was bright while the battery seemed to be charging. As time went on the meter kept showing that charging was taking place. I had noticed that somehow the air was heavy and something was going on, almost like a feeling of some kind, a permission that something was wrong with this experiment. When I stopped the experiment to test the battery it was exactly as it was when i started the test, nothing gained, except for one thing the battery did not have any capacity according to the analyzer, it dropped right away. Then I said how could this be and picked up the gel cell and it rattled like it had bbís inside of it, this was a real good battery because i had used it the day before running motors and it charged fine with the SG. I did not think about this at first and said to myself i will start over with another good battery, from my experience anything can happen to a battery, but it did not end here. I hooked the circuit up again and let it run overnight, i noted the voltage at 12.34 volts at 70% capacity on the analyzer and went on my marry way home. The next morning i expected the battery to be charged. I looked at the meter at 5:30 the next morning, the volt meter said the exact same thing 12.34 volts and i got near the meter and it did the same exact thing the digital display went nuts and the same feeling was there heavy
    feeling air. I then shut the oscillator off and proceeded to analyze this battery, the battery dropped like a rock and it only had 20% in it and going down each time i tested it, i said this can not be and disconnected the battery from the circuit, i shook it and it also sounded like it had bbís in it, now i knew that i had something going on that was not right. I showed this to Peter, just to have someone else see it. I tossed this battery into the same pile of batteries. I then got another battery and made sure that it would take a charge from the SG and also from a standard off the shelf charger, it did. I charged this battery and drained it down with a car headlight with both filaments connected together, about 90 watts. I then hooked it into the system again, I noted the voltage again at 12.03 volts at 20% capacity, i let this run all day putting up with that feeling of a slowed down world and a heavy pressure, i have never felt this way around the SG or anything electrical. When i tested this battery the next morning it was at 12.65 volts, even when the meter said 12.65 until i got near the meter and it went crazy again, i disconnected the oscillator and did a capacity test it went down to 8.5 volts and the analyzer just shut off. This battery also sounded like it had bbís inside of it, and another went into the pile of useless batteries. As i said in the early post the one wire system is an electron sucker it will render things useless when it comes to batteries, the wave shapes are of such a form that it looks like a continuous stream of ringing spikes very sharp, it will move a compass needle on the one wire indicating a current of some kind unknown to me at this time. I also said that it would charge a capacitor very fast and run motors of a certain kind, that kind being reluctance type motors. This is where Tesla was heading when he announced he had found a new use for iron, it is what powered his car, this is not the Gray engine at all. Teslaís patent shows very uniquely this type of motor in a crude form, in his radiant patents.Tesla would not have used a coil of wire on the rotor with brushes. Teslaís motor that he was working on was a reluctance type motor using capacitor discharge, the one wire system will run this with no current to charge the capacitor, i have done it , it works that is all i can say about it at this time.
    More on this motor later.
    Hi John,
    I ve been following your work since 6-7 years now and was in tune with the latest updates in your website.
    i have tried to replicate most of your beautiful looking machines on the website with good results and a proper understanding of the Radiant Electricity Physics behind the succesful replication.
    it is a privilage of life time to have a person like you who has spent decades on the development this magnificent Science of Tesla.
    I will soon post with pictures of my Replications of your Machines. this i regard as a mark of tribute to you John.
    Bye for now,
    Best Regards,
    1,529
    Geoffrey,
    Yes I understand what you also have gone through, But we must move on. What will happen is inventors will just make it very difficult to steal circuit and inventions. I for one will hy-bird everything. Congress has no touch with realty anymore as they never worked a real job, they just suck money, and that is just an example to the young people, you can steal what you want and it's ok. But hopefully we can all move on and build something for the future.
    Hi John,
    it is a boon to a Free-Energy Inventor like you, where the very Nature of Radiant Electricity shows up it self in different variants to make it convienent to be Engineered in avarity of configuration to avoid duplication and reverse engineering .
    rgds,
    1,529
    Hi John,
    Why does the patent office disallows the one -source -charging mulitiple Battery claim?
    is this so apparent on the Over-unity aspect of the Invention?
    Strange...
    rgds,
    1,529
    Quote Originally Posted by LesK View Post
    I just hope we all understand that one does not count for the many that support. thank you for this site to help us get things right. I can see from out here in the woods that John k. and Tom C. have obviously been a great help among others.
    So in the spirit of moving forward, I am grateful for the information on the SS Tube and for getting to make a replication. Although I have never liked any of the SS stuff before and had very bad experiences with it.
    I see that the coil has an amount of energy to transfer and that it can divide this energy to multiple batteries based on differences of impedance. In my testing so far the gap between two similar batteries at different states of potential is closing the gap fast. I see this as one very practical device.The practical application of this becomes quickly obvious.
    I don't understand Lameller currents very well, but here is how I see what is going on. The coil has a fixed energy potential. That energy follows the path of least resistance as it exits the coil. So as a battery builds up an impedance the less impedance takes more of the energy. For example if I had 12 watts in the coil and two balanced batteries then 6 watts would go to each battery. But if the impedance is mismatched then say 4 watts to one battery and 8 to the other.
    Outback inverters came out with a balanced inverter system about 10 years ago. It was designed so that if you had two 2000watt inverters you could put one inverter on one leg, and the other inverter on the other. This was a common practice and Trace and others had a wire you would attach between them to keep in phase. But what was unique about the outback is that the inverters would put and could put all 4000 potential watts on one leg based on the demand. Not an easy thing to do. I see this as very similar.
    The thing that is so mind blowing about this SS unit and being able to do this with the SSG is that is it's done with apparent simplicity. My complements, adulations, and general thanks!
    So I have two questions I would like to have confirmed so I can move forward.
    1- I understood that with this method you would need a trigger strand for each power strand, is that true for the SS and the rotored SSG?
    2- Does the SS version have the same qualities as the SSG in that you cannot swap batteries?
    Clarification on these two points would be extremely beneficial.
    Les
    Hi the Lameller Currents have direct relation to the number of plates in a battery..relate this to the Number of coils you use...and the main essesnce to open the loop and make the path way of the Radiant Energy
    you have it then..this is as far as i can guess the branches of the current of Radaint Electricity.
    1,529
    Hi ,
    There is one more gain mechanism that can be done to depict the Internal Impedance of the Battery,
    this mechnaism is used by Stan meyer(he called it Amp inhibiting coil) and i have thought of it (1998) even before i read his patents on google.
    I call it Self -Polarizing Inductor, which limits the Current in action and maintains a Dynamic Impedance shift along the Polarization. there is meterial change involved here.
    Member
    Subang Jaya, Malaysia
    45
    yes, it worked for me too.
  10. #110
    Member
    45
    ...But you can see what happen here and why I put the information away until the Patent was issued. And you can see they never made it work the same, Stan destroyed the transistor and the compound on the chip and should have studied this a little more on solar panels.But this is the history of what happened. Here, This is the history of the SG Radiant Oscillator and how things get stolen even when you have people you trust to be helping you We were also studying the negative effects and had built a machine to measure transistors, we just did not guess at this we measured it. And built oscillators Rick and the rest of the gang never have seen. So you know the story of why now.
    Hi John,
    Now it makes sense. Allow me to explain.
    I bought the SSG monopole kit several months ago from the r-charge website and decided that i needed to teach myself as much as I can about this radiant energy before actually building it. Then about a month or so ago, I introduced an interested party to this technology. He called up the number on the web site and was told(by RF) that the kits were no longer on sale. I was surprised and did not think about it. It was not until i joined this board that I found out what was happening/happened.
    I just wish to record my sincerest thanks and gratitude to you for continuing to do the work that you do and to be a guide to those of us wanting to learn this technology.
    sincerely,
    tejinder
