Four Wave Mixing
  • Power Resistor
    Originally posted by blackchisel97 View Post
    Well, I can't really suggest anything to anyone but I would like to get this device working properly.
    Since we know the pulse rates of each oscillator as well as their duty cycle - 50% that is the goal. I don't understand the purpose of pumping more mA into 555 by lowering the resistance to the treshold. I just noticed that my solderless proto board (plastic) got slightly melted under the first chip running at first with 120 Ohm, before I replaced with 150. That was absolute minimum in order to make it work at all.
    500 - 600, or 680 Ohms will do but 1k is quite common and will help us to compare data.
    Vtech
    Why don't you use a power resistor?
    You can calculate with the formula: P = I² * R
    P = power in Watt
    I = current in Amps
    R = resistance
    By example: place an Amp meter in series with the resistor, when you read bij example 100mA (the same as 100/1000 = 0,1 Amps) 0,1 * 0,1 * 150 Ohm = 1,5W
    Higher the wattage of the components in function of the above calculation and they can handle the heat.
    Nice greetings ;-)
    • The problem is not how to dissipate 1.5W in serial resistance but rather WHY. Single oscillator shouldn't draw more than few mA and 0.125W rated resistor not suppose to get even warm. Why would you want to pump Watts into this poor tiny creature in a first place?
      Vtech
      • Originally posted by blackchisel97 View Post
        Vtech
        Ok, i use always higher rated components for the life time of the "device".
        How far are you with building this device?
        I know that this Bedini/Bearden device is so strong that you don't need a magnetic pulser anymore.
        I hope John will soon post more details about the working of this device so i can help my sister, she has HIV.
        Thank you for sharing this information, i have ordered the components and i will also build this beautiful device.
        • If you read a few pages back You'll find that I built this already while ago. I also hope that this device may solve many health problems. I don't have an access to medical lab and don't own good enough microscope to see what it does in vivo and how to do final tuning. All I know about is what have been handed out at the conference and YT clips posted by other member.
          I wasn't there to ask questions therefore I cannot make any claims or provide more assistance beside what has been already posted. I'm busy with other projects a.t.m and will go back to 4WM once I can verify some details.
          There is no need to "beef up" components without a reason. It is better to understand the circuit working environment first.
          Vtech
            Thx Amigo and I think your second paragraph sums things up to a T. I realize I am off topic and in future will try to stay closer on topic however as I have John Bedini's welcome and invitation to keep posting I'll say a bit more. If you wish further reading on this here are a few links. For the baking soda in chronic kidney disease here is a free full text review of the literature from the American Journal of Nephrology, March 2012. http://content.karger.com/produktedb...339329&typ=pdf It is a bit dry reading, however the bottom line might be found in the discussion section where it states, "Our analysis revealed a net improvement in GFR of 3.2 ml/min/1.73 m 2 and a 79% risk reduction in the incidence of dialysis requirement by alkali therapy over the time span of the longterm trials. These results have potentially important implications for the clinical course of patients with CKD and the economics of end-stage kidney disease programs." So this was just oral baking soda and the dose about a 1/2 tea spoon in these studies. Chronic Kidney Disease is I believe the sixth most common casuse of mortality in the U.S.
            For the salt and heart disease here is the 2011 Journal of the American Medical Association study. JAMA Network | JAMA: The Journal of the American Medical Association | Fatal and Nonfatal Outcomes, Incidence of Hypertension, and Blood Pressure Changes in Relation to Urinary Sodium Excretion
            In this large prospective population the quartile of people who ate the most salt (as measured through urinary salt excretion) had 1/5 the number of deaths from cardiovascular disease as the quartile that ate the least salt. The study is important as well in that it is looking at actual heart disease rates (not a surrogate marker such as blood pressure - though the effect on BP wasn't seen as very large in this study either) and the endpoint of death is as clinically relevant as you get. Heart Disease is the number one killer in the U.S. In this large study at least eating more salt decreased deaths from heart disease by 80 percent. The American College of Cardiology still maintains its low salt campaign.
            For vitamin C reading I would recommend Dr. Thomas Levy, MD JD. some of his "Curing the Incurable: Vitamin C, Infectious Diseases and Toxins" is available for free on his website Books by Dr. Levy. Finally here are two reprints of Dr. Edward Klenners work with vitamin C, the first a 1949 paper dealing with his cures of Polio and other virus and the second from 1971 dealing with other therapeutic uses of IV vitamin C.
            Dr. Klenner: C as Polio Cure (1949)
            Klenner 1971 Vitamin C paper
            At some point here I will probably restart my medical blog and will be certain to try and let you know. Thanks for the encouragement.
            I am new to this site and loving it. My studies and research have been in the Natural Health field and I owned a health food store. The references above to soda are correct but it must be organic as the regular baking soda contains aluminum. Also the references to salt .....must be sea salt which contain all the minerals, table salt consists of only sodium chloride, no longer contains iodine, also dissipates over time in a shaker. Almost everyone is iodine depleted, Iodine used to be the UNIVERSAL medicine along with MAGNESIUM (preferably transdermal) The lack of these minerals is responsible for many illness'. However today we are talking about CANCER, the most natural successes I have seen have been from the use of marijuana oil, one drop of this oil under the tongue every night for 6 weeks can deal with some of the worst forms of cancer. Juiceing the leaf throughout the day is also beneficial and THC is not activated in the raw leaf so there is no "high" but much nutritional value.
            I am very interested and excited about the discussions on red & near infrared led therapy, Aaron mentioned a "function generator" to use with the panels to control Dr. Nogier's frequencies. Where would one get this device? Thank you all for your input.
            • Originally posted by Gail Jones View Post
              Hi Gail, Thank you for joining and providing additional clarification.
              Please visit Light Therapy thread for more information. I'm working on the device which will pulse LED panel and pointer using Nogier frequencies. Almost done with it.
              Vtech
              • Today I went back to 4 Wave circuit and built another one from scratch. However, this time I used HCF4047 instead of LM555 for all seven oscillators. OpAmp is the same - 386 and H11AA1 opto as per original diagram. Since 4047 holds 50% duty cycle the only thing left is adjusting output pulse rate. I got first four oscillators tuned with same value - 10nF capacitor, the remaining two on 1nF and slow pulse timer on 1uF. First three frequencies are 50, 150, 350 - as were given by John. Next three are: 1,500, 7,000 and 10,000. Pulse timer set on 7.8Hz. Total current draw is about 10mA at 12VDC. I'm still testing the output part and different transistors. I don't see a reason for 3055 (which is a power transistor) being used here but will try couple different ones. I checked all output waves from oscillators, OpAmp output and everything seems to work fine. I'll post more details later.
                Vtech
                • Ok, an update. Below is a list of component values for all seven oscillators from the top down:
                  IC1 50Hz, 470k but due to the tolerance it may get you at 49Hz. It is better to use 180k&270k in series + 20k trimpot.10n cap.
                  IC2 150Hz, 150k & 10k trimpot and 10n cap
                  IC3 - 350Hz, 56k & 10k trimpot and 10n cap.
                  IC4 - 1.5kHz, 10k & 10k trimpot and 1n cap. Following original values from the schem. 680, 100k, 47n will result in 153Hz which I believe is wrong since we already have 150Hz. If this was a printing error and it should read 4.7n the frequency will be about 1.526kHz @ 50%dc. I took this value as valid and set IC4 at 1.5kHz.
                  IC5 - 7kHz, 27k & 10k trimpot and 1n cap. This is the same value as calculated from the original diagram.
                  IC 6 - 10kHz, 18k & 10k trimpot and 1n cap. I listened again to YT where John mentioned "going all the way up to 10kHz". I don't know if this was a comment regarding the last oscillator but it seems in place. Unfortunately, I wasn't there.
                  IC7 - 7Hz, 20k & 10k trimpot and 1u tantalum cap.
                  Outputs from pin 10 (Q) of each six oscillators are connected via 10k resistors together - same mixing line as per original.
                  Output from IC7 - low pulse timer connects via 330 Ohms to pin 2 of H11AA1 optocoupler, as per original.
                  Everything else from the original circuit remains the same. Transformer primary (high impedance) is marked with "P". This side connects to the output of OpAmp via 1000uF capacitor and second terminal to the ground connection (Negative).
                  If you accidentally swap the primary with secondary and connect the electrodes to your temples it will knock your socks off and you may experience some colorful flashes for the next 30 min so please pay attention to this little detail.
                  Vtech
Name:	4 Wave Mixer2.jpg
ID:	45562Click image for larger version
Name:	4 Wave Mixer 4047 oscillators.jpg
ID:	45563Click image for larger version
Name:	4 Wave Output scope.jpg
ID:	45564Click image for larger version
Name:	4 Wave transistor base.jpg
ID:	45565Click image for larger version
Name:	4 Wave mixing line.jpg
                  The file names for the above pics should be swapped between output and mixing line.
                  Update: I tested few transistors and 2N2222 seems to be a good candidate. I have an identical output to the one from 2N3055.
                  • This is assembled and running 4 Wave device with 4047 modification. Sixth oscillator (10kHz) may have 10k & 20k trimpot instead of 18k & 10k. This way it can be adjusted between 10kHz-20kHz if needed.
                    Vtech
Name:	4 Wave assembled.jpg
                    • Hello BC, that looks interesting, I'm messing around with other stuff but will get back to this at some point.
                      • Originally posted by Thunderlance
                        Micropulsing Applcation: Frequency through electrodes is ~3.92 Hz or half of the earth Schumann frequency of 7.83 Hz, (+/- 1 Hz) with a BI-PHASIC Square wave@ 31 Volts (+/- 1Volt ) peak per cycle. Maximum current through the electrodes is ~8 milliamperes into 1,000 ohms, ~ 12 milliamperes into a short circuit at 31 Volts peak per cycle. Output voltage is a nominal 31 volts (info from Dr. Becks endorsed Product )
                        I believe you have posted in the wrong thread since this is dedicated to John's device, not Bob Beck.
                        Vtech
                        • can i ask a stupid question?
                          once i have my circuit built and it appears functional, how am i supposed to verify it works?
                          • Originally posted by slloyd View Post
                            Hi slloyd,
                            Your question isn't stupid at all. Matter of fact it is a very good one. Now, it makes two of us wondering.
                            Vtech
                            • my guess is that you have to grow some sort of micro organism in a peatry dish, verify (somehow) that what you grew is what you wanted .. and then destroy it. the organism you chose to grow should be on the list of known frequencies so you have some idea where to start from and also should be fairly easy to grow (surely some are more difficult than others to cultivate).
                              so i'm wondering which one is a good one to select?
                                My question is more of technical nature: since this device works on contact with skin tissue how do we suppose to conduct such test? We cannot simply attach the prongs to the slide since the potential and current will destroy our specimen. We may as well crank up the halogen bulb under condenser and claim that light wave killed everything, while it was a heat. 9V battery will do the job just fine.
                                We're not dealing with electromagnetic field, or plasma tube driven by MWO or Rife type device where the effect can be observed by placing specimen under the microscope in the field and observed.
                                According to TomC there should be a kit available as well as tuning instructions so we may finally get some answers and clarifications. This is fairly simple circuit to build but we need more info to make a use of it.
                                I have no intentions of mass producing or providing pcb's for it since it belongs to John. All I want is to replicate (already did) and use it for myself.
                                Vtech
