Can I use higher wattage resistor and potentiometer for SSG?
  • Can I use higher wattage resistor and potentiometer for SSG?
    I have a 100 ohm, '1' Watt resistor and a 1k ohm '2' Watt potentiometer, for my first SSG project. is the higher wattage going to be an issue?
    "resistors, 100 ohm 1/2 watt and 1k ohm potentiometer same wattage"
    Thank you in advance for any insight.
    Ahmad.
    Ahmad,
    No that will be fine.
      John, does that also apply to a 100w 1k rheostat?
      Jamie
        James, yes it will be find, if you have one.. anyway, a basic SSG doesnt need a very top notch rheostat, since it draw relatively low current 80-120Ma..so a simple 1k pot will be just fine..
        Alfin
        PS: start tuning from the higher resistance to lowest, until you find the lowest resistance with higher RPM
