Hello John:
Love your research and I try to keep up!
I took a car battery from a 2007 Kia Optima and dumped out the acid. I rinsed out with clear water and then mixed my alum and distilled water. I used Alum Aluminum Sulfate. My battery takes about one gallon of water. I mixed 1 and 1/2 cups of Alum to the gallon and put into my battery. I charged over night at 2 amps. It never seemed to completely charge. The battery started off weak from the beginning but would start the engine. This was two weeks ago. About five days ago the battery after sitting over the weekend was so dead it could not turn over the engine.
When the engine is running I get a reading of 12.81 to 12.90 volts and can jump to 13 Volts. When I turn off the engine the volts immediately drops to 9.97. When I first turn off the engine the battery makes a hissing sound that gets slower and then stops all together. The battery does not seem to keep the charge.
What is the solution to solving this problem. What have I not understood or what have I done wrong?
YoderIII
