Results 1 to 10 of 11
Thread: 10A12 Charger & Rejuvenator
    10A12 Battery Charger
    10 Amps, 12 Volts
    * NEW *
    Like the 2A12 but with 5 times the power!
    The 10A12 delivers a fast, but remarkably powerful and revitalizing charge. Can easily restore a vehicles cranking power to start the engine.
    • Easy-to-read LED status displays state of charge.
    • Lightweight and very portable.
    • See owner’s manual for more details.
    • Physical - 6"W x 5"H x 8"D - Approx.. 10 lbs.
    • *1 Year Warranty
      GET YOUR OWN 10A12 ENERGENX CHARGER & REJUVENATOR: ENERGENX 10A12
    I just got one of these and I want to use it to charge the primary battery for my monopole. I know you can't use a radiant charged battery as the primary, but is a battery charged by this charger radiant charged or is it conventional charged? What I'm really asking is if it's ok to charge up my monopole primary battery with this charger.
    thanks,
    Robert
    1,438
    Hi Robert,
    It is not a conventional charge but John did design it to charge batteries so that they will still be compatible with conventional chargers. It is an excellent charger to use to charge your primary battery.
    Nov 2012
    prince george canada
    3
    hi. i have a question: can this chargers be used for other types of batteries? i am specifically looking at lifepo4 batteries. i have an ebike and i am interested to use radiant energy as means of charging. is it possible? my battery is a 48v. i know this charger would charge at 12v only. i just need to know if it would work with dry batteries aswell? thank you
    Would the 10A12 work well charging a pair of 6 volt golf cart batts?
    bro d
    1,438
    Quote Originally Posted by adrianjustmee View Post
    These chargers are not for lithium batteries. There is a risk of fire, damaged electronics inside lithium batteries, etc...
    What do you mean dry batteries? It works on gels, nicad and nickel metal hydrides.
    1,438
    bro d
    It could but I would make sure both batteries are very closely matched in their condition.
    Feb 2014
    160
    Clarification about features of current model
    Can a representative for Energenx please clarify the features of this charger as of December 2014 for the benefit of potential and existing customers.
    I have been advised that this model is now a Pure DC Linear Amp design, meaning it does not pulse charge. My understanding is that this good for new lead acid batteries and LiFePO4. But what about rejuvenating sulphated lead acid batteries?
    1,438
    Hi James,
    The 10A12 is the linear regulator so does not pulse. It can rejuvenate batteries great but is intended to mostly be a charger. If you do multiple charge/discharge cycles, it will work wonders because it gets the batteries to the proper voltages to get the final layers of sulphation off.
    The 10A12 is not meant for lifepo4 batteries because it pushes it .2-.4 volts too high - those need to be capped at 14.8v.
    Email us at the email on the banner in my signature and Jeff will respond with details. John probably won't be back at the shop until Jan 2nd or so.
    Take care,
    Aaron
    Feb 2014
    160
    Would you expect similar results to the previous pulse charge model, even if it took a few more cycles? Possibly a hard question to answer because all batteries behave differently.
    Or is time and money be better spent building an SSG for battery rejuvenation?
    If I can offer some advise for both Teslachargers and Teslagenx that you consider changing the wording on your websites about this charger, the "5 times more power" association made with the 2A12 gives the impression the 10A12 is also a pulse charge model, at least it did for me... not to mention the manual still explicitly states this. My own interpretation was that the 10A12 was a linear amp/pulse combination unit, this is what I currently thought the 2A12 is but now I'm not sure.
