Ludwig Relaxation Oscillator / Magnetic Pacer
  • Ludwig Relaxation Oscillator / Magnetic Pacer
    Hi Everyone,
    I came across a schematic diagram mentioned by Dr Bob Beck whereby he called it a Magnetic Pacer or Ludwig Relaxation Oscillator.
    http://www.docdroid.net/5nbw/magnetic-pacer.pdf.html
    The circuit is suppose to generate a 7.8Hz field to protect us from other harmful frequencies.
    Not much description provided except a circuit diagram and the case layout.
    I have difficulty understanding it but I would really like to build one.
    Could everyone here help and give me some advice.
    My questions:
    a) Where is Q1 transistor 2N1563 collector connect to ? Where do I find the connection to Guassian noise 600MHz ?
    b) What kind of relay coil is L1 ? Can I make my own 15Kohms L1 coil ? What size enamel wire should I use ? How many turns ?
    c) How does the signal null detector work ? How does the thermocouple and diode work ? Where can I find these parts ?
    d) Inside the plastic case, insulate 3a and 3b were used. What is the purpose of sandwiching the diode and thermocouple ?
    e) What kind of device is connector to socket J1 ?
    Thank you very much for your help.
