Apologize for not knowing English and use the google translator
THANKS is the least I can say all that you are doing. As I have said repeatedly I'm just a kid from uneducated people . but since February 2013 'm locking hard attempted to replicate the inventions of John Bedini 's genius that gets me up at 09:00 am and ends the next day at 07:00 am sleep three hours and return to work until your eyes close on their own and start seeing double when you set the look hehe. Now I'm trying to replicate the windows and I passed by the turner for me aga aluminum rotor very similar to John Bedini uses in his videos though smaller scale . I think next week will miss the rotor. As I made experiment with the circuit and put a coil rodding R60 in the core, hard disk rotor , Neodymium magnets , transistors 2N3055 and MJE2955 , I have made germanium diodes 400 volts, 40V capacitor 100000uF , 12V 7Ah battery , potentiometer 1K 5W resistors 3.3 k 2.2 k and 10 ohms. Also I used a laminated magnetic switch at output of the rectifier bridge linking it with the battery positive . Here I have a doubt. Depending on where you place the magnetic switch I have a higher or lower amp draw . What would be your position when I have more when I have less consumption or consumption ?
THANK YOU ALL. If these questions already been answered an please pass me the link.
Disculparme por no saber ingles y usar el traductor de google
GRACIAS es lo mínimo que puedo decir por todo lo que estáis haciendo. Como he dicho en varias ocasiones solo soy un chaval de pueblo sin estudios. pero desde febrero de 2013 estoy trabando muy duro intentado replicar los inventos de John Bedini el genio que hace que me levante a las 09:00am y que termine al dia siguiente a las 07:00am dormir 3 horas y volver a trabajar hasta que los ojos se cierran solos y empiezas a ver doble cuando fijas la mirada jeje. Ahora estoy intentando replicar el windows y me pasado por el tornero para que me aga un rotor de aluminio muy parecido al que John Bedini usa en sus videos aunque a escala mas pequeña. Creo que la semana que viene estará echo el rotor. Mientras me puesto a experimentar con el circuito y le puesto una bobina con varillar R60 en el núcleo, rotor de disco duro, imanes de neodimio, transistores 2n3055 y mje2955, le tengo puestos unos diodos de germanio de unos 400 voltios, condensador de 40V 100000uF, batería 12V 7Ah, potenciómetro de 1K 5W, resistencias de 3,3k 2,2k y 10 ohms. También he usado un interruptor magnético de laminas en la salida del puente rectificador uniéndolo con el positivo de la batería. Aquí tengo una duda. Dependiendo de donde ponga el interruptor magnético tengo un mayor o menor consumo de amperios. Cual seria su posición correcta cuando tengo mas consumo o cuando tengo menos consumo? Es mejor usar otro tipo de interruptor?
GRACIAS A TODOS. Si estas preguntas ya an sido contestadas por favor pasarme el link.
