Lightning
  • Lightning
    Hi alll,
    Does somebody has expirience with the lightning method from page 34-47,has somebody built this circuit.Thanks for the info.
    http://www.panaceatech.org/Tesla%27s...Oscillator.pdf
    Sorry but the Tread should be called Lighting.
    I dont know why the link is not working.If you are interested take the link down from hobbyrobotik.
      Bad link..
        You are right..it does not open to me either...
          Use Google write
          [PDF] Imhotep's radiant oscillator - Panacea Technical
            Originally posted by forelle View Post
            Hi alll,
            Does somebody has expirience with the lightning method from page 34-47,has somebody built this circuit.Thanks for the info.D:\Tesla's HV impulse lighting methods-Imhotep's Radiant Oscillator.pdf
            Sorry i dont know why its not opening.
            Excuse me for the problem.
              Try the following link
              Hello Forelle,
              the following link should work
              Dieter
                Using Google writes [PDF] Imhotep's radiant oscillator - technical Panacea
                  "why-me" how u downloaded? that link is 404
                    link die
                      I found this fruit slot games
                        Hi Corrin,
                        hobbyrobotik had the link correct in post #7. Here it is again. http://www.panaceatech.org/Tesla%27s...Oscillator.pdf
