Results 1 to 10 of 16
Thread: Help with Mosfet
    Help with Mosfet
    Hi Guys,
    I am wanting to play around with cap dumping using mosfets and I have actually ordered these specific models.(Link to data sheet below)
    LINK:
    http://www.infineon.com/dgdl/IPx50R1...39d43facbe02fb
    My basic idea is to use a smaller NPN to switch the gate on these guys which will control the cap dump through the drain/source. I will be putting the switching on the neg side to the charge batt.
    I thought I understood what I was looking at but now I am a a bit unsure of the specs for driving the gate on these and I am hoping someone with more experience can look at the sheet and help me understand. At what voltage and current would I want to hit the gate with to have it fully open the D to S?
    I initially really liked the looks of these mosfets because of the very low resistance across the DS. In addition they are rated for high voltage and 60+ amps so I think they should do well.
    I am not experienced with these devices so if anyone could help me figure out the proper way to switch them I would appreciate the help.
    BobZilla
    Hey Bobzilla,
    I am by no means an expert but I am working on the same type of cap dump.
    You have here an n-channel MOSFET with a min/max Vgs of -20/20V. To the best of my knowledge 20V at the gate will turn it all the way on. I'm not too sure if 0V or the -20V turns it all the way off. I would think 0V would do it.
    As far a current goes there is hardly any current drawn from a MOSFET. There is no physical connection between the gate and source/drain. All you need is the 20V potential across Vgs and you are good.
    One thing to keep in mind though is that you need a resister (about 100K should be good) across Vgs. You can't just say, (hypothetically) hook a 20V battery across Vgs and dump the cap. I don't really know why it is needed but I couldn't get it to work without one.
    What are you using for a timing circuit? I tried building one using 555 timers but ended up using an arduino.
    Anyway....hope that is somewhat of a help!
    -Joe
    Thanks for the advise Joe.
    I have chosen the arduino as well ;-)
    I had never used one before but it seemed like a good place to start. So far I have just been writing small loops to control LED's while I wait for my mosfets in the mail. I plan to work with small voltages and practice switching a light bulb at first and then on to a cap dumper once I'm comfortable with it.
    I have also been thinking of other possibilities with the arduino. I think SCR's could be used instead of mosfets if you code another channel for a pnp to break the flow and keep the SCR from latching. It's all about setting up a clever timing system and with the micro controller it should all be possible.
    Perhaps you and I can exchange some ideas for using this platform once I get my feet wet.
    Absolutley! What are you using for a storage Cap?
    I have ordered a 60k uf 75 volt cap. This will be a bigger system than I have played with so far.
    I have made various systems with bunches of flash caps in parallel and some other 1500uf that I got dirt cheap but now I am wanting to build bigger. I have not used this method for switching before but I have had a lot of success with my small systems with various switching methods so I'm confident I can move up to bigger and better now.
    At mouser it is part #75-36DX603G075DJ2A
    I have been playing with my solid state builds for the last year but I'm starting to shift back to the mechanical wheel now. SS is fun but I think more can be done with a mechanical setup.
    I did a test circuit with the arduino tonight using a small npn tranny and just had it switching a light bulb off and on. I was powering it with a 9v battery and I tell you it did not last long (few hours). I did a current check from the battery and it was pulling 50-60ma just to run the board and switch the transistor. I'm talking about the switch circuit, not the bulb load which I was driving from a different source. I will be working on adding a generator coil to my mechanical setup and see if I can pull enough off that to run the switching circuit.
    Bob,
    Have a look at US Pat 6677730.
    https://www.google.com/patents/US6677730
    I've tried the cap-discharge side of that circuit long ago using a 555 instead of the SG3524.
    I was dumping a 22,000uf cap into a 12v LAB at about 24v.
    I had 2*10 turn pots on the 555 and was able to adjust the dump time to almost nothing so the cap didn't discharge completely.
    With a very short dump time, the battery was "ticking" just like when using the "spanker" (2A12) and all the wiring was jumping around.
    The mosfets were getting hot only when the dump time was very short. I was using IRFP250Ns.
    No proper scope so I can't tell you how long that dump was...
    Martin B
    Just a tip of advise if your working on this cap dump charger. You need the resistor 10K to pull the gate off or the fet will stay on. The SG is ideal you just need to understand how to use it. It can be made to run at 10 to 100 cycles but remember that is divided by two. Pin 10 of the SG can be made to regulate the battery. The best data sheet is the TI somewhere I have the original RCA data sheet that tells you much more then what is now on the net. You should run this in inverted mode you just need to switch the fets around. Many things can be done with SG 3524 that most people do not understand, but then again I'm an Analog Engineer and have been so for 40 plus years. SCR will work and you need nothing to turn them off if you run inverted mode with them, you can not run them above 30 cycles or they will not turn off, think about what I said here.
    John B
    One more thing I want to bring up is that if your going to run the SG at high voltage use a resistor zener diode combination. also zeners can be used on the gates on the fets for over voltage.
    sg2524.pdf
    Quote Originally Posted by Joster View Post
    Hey Bobzilla,
    -Joe
    John Bedini
    Thank you Mr. Bedini. You have given me much to think about.
    I am trying to use an "Arduino" for switch control. I'm not sure if you are familiar with these but they are programmable micro controllers for hobbyist. Through software you can set timing for different channels to flip on or off etc. very precisely. I am trying to emulate the principals you have laid out but I do not have the level of experience with components required to build it as you would.
    I look at it as a way for someone like myself to cheat a bit. I know you have a profound understanding of circuits and you know the best way to do things.
    Again I want to say thank you for everything you have shared with us all and it's really nice to see you back on the forums! ---Bob
    *EDIT*
    I wanted to make clear that I really appreciate your uploading the data sheet and that I am not dismissing in any way what you have said. This is very valuable information and I am going to try and understand.
    You may be able to use a Logic Level MOSFET with something like a 100ohm resistor from the arduino pin to the gate and a 10k resistor from the gate to the ground. The 10k resistor prevents the gate from floating like john said. If you don't use it your cap can dump while doing things like programming the arduino.
    Another option is to connect a 10k resistor from vcc (probably needs to be 10+ V) to the gate and connect an optocoupler between the gate and the ground. With this arrangement the cap will dump when the arduino pin is LOW, although I may be wrong. See this DLE-TEST25 : Regenerative Loading with the J. Bedini's unipolar motor piloted by the APMC v1.0b
    Position a solar panel with an iPhone/iPad with Solar Tracker!
    http://solartrackerapp.com
