Bedini RPX Sideband Generator
2019 ESTC ALL SEATS SOLD OUT!
PRE-REGISTER FOR THE
2020 ENERGY CONFERENCE
Monero XMR
Results 1 to 6 of 6
Thread: Self-Recharging Battery Supply of Carlos F. Benitez by Peter Lindemann, D.Sc.
  1. #1
    Join Date
    Jul 2012
    Location
    Spokane, Washington
    Posts
    1,439
    Blog Entries
    1
    Thumbs up Self-Recharging Battery Supply of Carlos F. Benitez by Peter Lindemann, D.Sc.
    NOTE: This machine was demonstrated at the 2018 Energy Science & Technology Conference (ESTC) but there was no formal presentation. It was only explained to attendees who were interested enough to ask Peter Lindemann questions about it back in the vendor/demo room. This machine is a very small powered demonstration, but proves the point and kept itself charged up all weekend while running a motor/generator. This EXACT circuit from 100 years ago is the foundation for several well-known circuits that have been taught by John Bedini and others over the years - you are being handed the origin of where much of it came from.
    Get your copy here: The Self-Recharging Battery Supply of Carlos F. Benitez by Peter Lindemann, D.Sc.
    Between 1915 and 1918, Carlos F. Benitez was issued 4 British Patents on a "System for the Generation of Electric Currents." It was the early days of the "electrical era" and many experimenters were claiming new ways to produce useful electrical effects. But this was different. Benitez was claiming to be able to run light bulbs and motors from batteries that never needed to be re-charged from a conventional, external source.
    By this time, the Laws of Thermodynamics had become widely taught, and so most electrical engineers did not take these claims seriously. Even today, 99% of scientists and engineers believe this is impossible, under any circumstances.
    Here's why: Classic electrical theory assumes that when a load is operated in the manner shown here, the load RL receives of the power provided by the 12 volt supply, and the 6 volt battery wired in reverse receives the other half as a charging effect. Since the battery being charged only receives of the energy supplied by the source, rotating the batteries back and forth runs them all down in a conventional manner.
    So, it is curious to find this quote in one of Benitez's Patents:
    "Obviously the current furnished by the discharge of battery 1-2 alone, would produce a smaller charge in batteries 3-4, if some extra energy were not added to the normal output of said battery 1-2. With this object in view any of the known methods for the generation of high frequency currents, as well as those described in the aforementioned English Patents, can be employed in conjunction with said batteries, in order to provide that complementary energy, and in this manner it is always possible to charge and discharge alternately each battery from one to the other, maintaining constant a storage of electricity and producing furthermore an excess of electrical energy."
    On the Patents, Benitez is referred to as a civil engineer, living in Guadalajara, Mexico. So, while he may not have been earning his living in the electrical sciences, he certainly was familiar with both classic electrical theory and the benefits of his discoveries!
    For any honest student, the questions become: Was Benitez mistaken, or did he discover something important? And if so, HOW is this possible??
    Benitez was issued 4 Patents, and each one describes a different circuitry and method to accomplish the objects of the invention, which included running external loads AND returning the electrical source to its initial state of charge simultaneously. Since there was no dispute about how much energy was being dissipated by running the loads, the following conclusion may be drawn:
    Benitez discovered that it was possible to return a battery to a higher energy state with fewer watt-hours delivered to it than classic electrical theory would predict, as long as that energy was applied to the battery under the correct conditions and in the proper manner.
    Today, we would describe this as the ability to charge a battery at a COP > 1.
    As John Bedini always said, the "gain" showed up in the battery. The circuits themselves always operated at an efficiency below 100%.
    If we assume that in the circuits that had two banks of batteries in them, the charging batteries were receiving about of the energy provided by the run batteries, then the circuitry had to overcome the loss of running the loads and the loss of running the circuitry itself. In this instance, the system would have to be able to produce a charging effect in the receiving batteries equal to 2.2 times the watt-hours provided, or a charging COP > 2.2 for the system to self-sustain indefinitely.
    So, the GOAL for an operating system is to attain a battery charging efficiency with a COP > 2.2!
    That said, there are other ways to accomplish the goals of the invention, but "super-efficient" battery charging is definitely one of the ways. For students familiar with the work of John Bedini, this method is the best documented and published on, as well.
    NOTE: This presentation gives you the EXACT schematic to replicate Peter Lindemann's circuit that he demonstrated at the 2018 ESTC, operating theory, supporting diagrams and complete explanations of how to operate it. Also, there are multiple URL shortcuts inside the zip file that are highly relevant to this technology. Some are to other presentations and some are to specific discussions at Energetic Forum.
    Get your copy here: http://emediapress.com/peterlindemann/benitez/
  2. #2
    Join Date
    Sep 2012
    Location
    Bangaluru, Karnataka, India
    Posts
    1,529
    Quote Originally Posted by Aaron Murakami View Post
    Looks like this book is a must to understand the 'Tesla Switch' and the other mechanism that provide COP>1 in charging and Discharging (Powering a load) simultaneously.
    also, i read Rick spreading the garbage of discrediting John's chargers and that stating that it kills the batteries.. one must get enlightened to judge the truth..i guess this book will say it all!
  3. #3
    Join Date
    Jul 2012
    Location
    Spokane, Washington
    Posts
    1,439
    Blog Entries
    1
    There is a 45 minute presentation but the pdf does have the supporting documents.
    Rick is a sociopath - not much else needs to be said about him.
  4. #4
    Senior Member Yaro1776's Avatar
    Join Date
    Aug 2012
    Location
    Heart of Vermont
    Posts
    345
    Hello Aaron and Peter,
    I viewed the Benetiz video over the long weekend and a big thanks is in order to Peter for putting together another informative and useful presentation. Enough historical information and an actual simple replication to flesh out exactly how this machine works. The fact that the end result is a high efficiency design configuration is an added bonus.
    Another intriguing build to add to my winter list.
  5. #5
    Join Date
    Jul 2012
    Location
    Spokane, Washington
    Posts
    1,439
    Blog Entries
    1
    Quote Originally Posted by Yaro1776 View Post
    Hi Yaro,
    I posted this in Energetic Forum yesterday. All the rest of the component numbers should be in the drawings - this is for the diodes in response to questions:
    From Peter:
    RS gave the diode numbers in his presentation last year.
    The large diodes on the ground line are the MUR3060PT. Its a dual ultra-fast diode for switch-mode power supplies, rated at 30 amps per diode, 600v, and 50ns switching. They share a common cathode, so I only use one of the diodes in each device.
    The smaller single diode in the motor circuit can be any fast diode rated for the power, like the uf4007. The exact diode used in the demo is the MUR860G. Its a 10 amp, 600 volt ultrafast diode with 35ns switching.
  6. #6
    Join Date
    Jul 2012
    Location
    Spokane, Washington
    Posts
    1,439
    Blog Entries
    1
    If the ZFM had just enough core material to give a significant spike on the discharge and had an isolated recovery winding, it could be run with this exact method. With the bipolar switching, not sure if it would work as simple as using a recovering winding.
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
