MrRonsen vanilla SSG, preconditioning of secondary on the way up to 14,5V?
  • MrRonsen vanilla SSG, preconditioning of secondary on the way up to 14,5V?
    Hello,
    my build:
    bicycle wheel 60cm diam, 16 magnets, 1cmx1cmx2xm
    Coil AWG 26 and AWG 23, 850 turns
    -> 80 RPM
    while amp draw 65/70mA
    1 ohm test around 50mV,
    using MJL21194
    primary battery: 7Ah
    secondary battery: 7Ah
    everything now is soldered with solid copper wires
    batteryies connected with clampings.. not one aligator inside
    charging goes on...
    in first hours secondary readings goes up faster than primary drops...
    but after some hours.. it nearly equals,
    how much should i charge up,( taking readings while charging, not after resting)?
    till 14,5V? or should i stop charging if 1 hour without significant raise occurs?
    after first few cycles(charge, discharge, even not yet getting up till 14,5V) ..
    we will reach 14,5V easily?
    i would like to make the 20 test cycles..
    http://www.energyscienceforum.com/me...nilla-ssg.html
