1AU - Universal Battery Charger & Rejuvenator
This is a sticky topic.
    Originally posted by gabiX87 View Post
    Hi, I already have the 1AU and using it everyday. Everything is working fine. I had to put the charger into the basement because of quiet loud buzz/noise/rattle while charging. It's kinda hard to be with it in one room while in operation. Is it normal? How about your charger ?
    Thank you
    The bigger the battery and/or the higher the setting, the more noise.
    As long as your batteries are within the rating for each particular setting, you're charger is fine.
      Another question.
      Can I charge two 12V power tool (or LABs) batteries in series as 24V on the 7 or 8 setting on the 1AU ?
      EDIT: With identical Ah rating and chemistry , of course.
      my work here :
      https://plus.google.com/u/0/photos/+...22301631177969
