See more
See less
The SG Radiant Oscillator
  • Also, if you work with branched outputs, the difference should become more noticable... no big mystery golden egg here, just another method to tweak and further enhance the performance.
    • A simple Tree-root system seems to teach me on the Branch currents
      Just my few cents to Understand the Branch- currents and what is missing in the group.
      Best Regards,
        You should see a difference using both setups you describe. The addition of a 2nd, 3rd... trigger winding is more basic than you describe. The accounting of effects you notice are perhaps a lucky tweak for your setup...
        Why do you have 3 different winding sections on the coil?
        Hey Min2Oly,
        I guess you are talking about the way the they appear..the intent was to wind them in a Same plane (flat pancake) this is the Natural geometry for bifilar coils,(even number) the third one as i said is a 'Ghost coil' there in essence )and i had to wind them in stages by using cable ties to be able to hold them in the same plane...that could be it
        Faraday88
          Hey Min2Oly,
          Faraday88
          Not the case
            Not the case
            Hi Min2oly,
            There are many queries in my mind?
            1) The JB Pat no. 6,545,444 is a trifilar coil arrangement but is distinctly different from its SSG mode of initiating the TIT(Tesla Impulse Technology) in the Magnetic Circuit.
            2)Remember the ' Plain Vanilla-coil' a term coiled early in the group for stricktly bifilar coil has no sole role in inititating the TIT impulses. which means a second set of coils does that in conjunction!!
            3)My experiments with the trigger mode for Bifilar and 'Converted Monofilar'(i will explain this a little later) have shown me the specifics for each in the forced mode and free running mode respectivily.
            4) The solid-state Radiant oscillators are advanced in the input sections as per the 'Circuits and related methods' patent i can say it is closely related to the Patent 'Pulse charging a battery and driving other devices with a pulse'
            5) The Cable oscillator is something what i called as the 'Converted monofilar' coil arrangement or geometry with a Ferrite/iron core in fact in a toroidal geomerty... recall the figures 6 nad 7 in the above mentioned patents it is the dual of the bifilar coil. Cable oscillator coil winding is an art i must say...
