Hi Gary,
Thanks.
I’m assuming the battery is never the source of current to the 555 chip, but that instead it's powered by current from the power windings (produced by the approach of each magnet). Is that right?
cap dump schematic questions
Hi Cmor,
Originally posted by Cmor View PostHi guys, ...........A quick question. The schematic shows a diode between the top of the power windings/battery positive and the 555 chip. Do all the power windings go through one diode or is there a separate diode for each winding?
Hi guys,
I had a bunch of unexpected delays (including my laptop dying) and am just now getting back on track.
Originally posted by Cmor View PostHi John,
I'm not ready to build my "next" cap dump, since I haven't even built the first one, but...planning ahead for when I do, does TeslagenX sell matched Mosfet's in addition to the matched BJT's?
Hi Michael,
Thanks for your thoughts.
I should have tried that while I've been waiting for my parts to arrive to make the cap dump.
Now they're here though and I'm going to pick them up tomorrow. And of course once I change the SG output from radiant energy to a cap dump, it will no longer be possible to do that experiment with the batteries.
Hi Gary,
That makes total sense, I forgot about the clamp side of those terminals.
Hi Micheal and Cmor,
energy REGAUGED BY THE FIRST SECONDARY BATTERYIn my opinion this is not a matter of regauging, but an issue of the energy being actually converted to something a slightly different form.
The quality of electricity, and the terms negative electricity and positive electricity are something else which I for one don't understand?
However, Aaron explained the difference between cold electricity and hot electricity at one conference that made a lot of sense to me. He described cold electricity as current doing work with no voltage and/or voltage doing work with no current. Hot electricity is when both current and voltage are present and doing work, like in a resistor. Watts = Amps x Volts
Hi Cmor,
Originally posted by Cmor View PostHi Gary,
That it a great tip. I'll do that too. As for specifics, to get good contact, did you wrap the Mosfet legs around the screws before screwing them in?
The wire and/or mosfet leg just slips inside a sleeve. Then a recessed screw forces a lug down on top of it. The leads are securely held between the lug and the wall of the sleeve. The sleeve goes all the way through the plastic mounting strip and has a screw clamp on each end of each sleeve. The circuit wire goes in one end and the FET leg goes in the other end of a common sleeve.
Cmor we are used to thinking in absolutes and rules, but I would like to run some ideas to you that are a bit more abstract. If I confuse the issue for you, just ignore me. Gary feel free to correct or override anything I write here.
1st a battery is not just a slow capacitor. A capacitor stores its charge in a dielectric field and a battery is a electrical charge – chemical reaction – storage – chemical reaction – electrical source device. They can sometimes be interchanged as a source but internally there are fundamental differences in the way they act.
The difference in the two charging methods are the sources. A coil stores energy in its magnetic field and on discharge has to make up the dielectric portion from the environment. A capacitor stores it's charge in a dielectric field and on discharge has to make up the magnetic portion from the environment. These two methods create a different quality in the electricity produced (which I do not fully understand) and effect the chemical phase of the battery charging slightly differently. This difference is why the batteries have problems with being switched.
The regauging that Beardon refers to means to me changing a reference point. In my opinion this is not a matter of regauging, but an issue of the energy being actually converted to something a slightly different form. Tesla said he could convert electrical energy at will, this may be a small part of what he was referring to.
All that being said I believe there is still too much not understood of all the effects that can be generated in a circuit. I think of Tesla's hairpin circuit and how if you add a capacitor you can sometimes add more loads after it. So if you you have some batteries you are willing to risk and the time to do a long term trial of your premise, I would say go ahead with the understanding that there is a lot more involved than your original statement indicated. Just let us know of your findings.
Michael
Gary,
I mentioned a couple posts ago that I'd read something saying if several batteries were hooked up (I said in series, which was an error) that those after the first battery would be conditioned, just like in a cap dump. You hadn't heard about it, so I wanted to post the comment to see if you or anyone else has more feedback.
I don't remember where I copied it from (though maybe from an instructable), but here it is.
OK, why CAN we swap batteries that have been capacitor dump charged, but not diode direct charged? Because the capacitor has REGAUGED the energy and we can use the battery as primary immediately. Well, the batteries being charged in line AFTER the first secondary battery, in parallel on the back end, have the energy REGAUGED BY THE FIRST SECONDARY BATTERY that is hooked up to the output of the unit. It is just like getting the energy through a capacitor! Batteries are just really slow capacitors, after all. The only battery that CANNOT be swapped to primary is the first battery in line on the output side that is directly hooked to the radiant output.
Faraday88,
I don't know the answer to the details you're asking, but I think the "matching" is in terms of when they turn on, so they all turn on at once.
what parameter of the MOSFET is needed to be matched?
Hi Gary,
Hi Cmor,
Originally posted by Cmor View PostThanks Gary. That's what I needed to know. I'll go with 5.
Given that they won't be matched there will be one that triggers first and conducts the bulk of the current. I imagine it will thus be more likely to burn out. At least now I'll know why.
You mean you attach them to one of these?
[ATTACH=CONFIG]7087[/ATTACH]
If so, do you attach them with the screws rather than solder?
Yes, those are the kind of terminal strips I used on my last cap dump with the comparator. And yes, I attached the FETs with screws so they would be easy to replace.
The FETs were soldered into my first (555 based) cap dump as you can see in the photo album I linked to earlier. Replacing them was not easy!
