Thanks Faraday. I remember you mentioning the depiction of the variable cap being a way of conveying the function, but not the specific hardware. I wonder though, would J.B. depict it this way in a diagram that he released to the public domain to assist people in building these units? I understand how it would be drawn that way in order to protect proprietary information in a patent, but I believe that drawing was not a patent drawing. I'm still trying to figure out what else could provide the same function as a variable cap without literally being a variable cap. Would simply using a variable cap work, or do we lose a necessary contribution provided by the "other method"? You definitely have me thinking, which I appreciate! I'm not the sharpest knife in the drawer, so give me some time.....and a few hints, maybe?
-Woody
Bedini Original machine FEG 1984
Hi Woody,
Looks can be diceptive! think over the 'VARIABLE CAP' again, its not the Physical variable cap as the diagram depict
in the drawings.
Thanks Woody,
I got the plans from this site http://www.metaphoria.us/hamradio/DL5DBM_cap_plans.pdf for a 220pF 5kV variable cap. It took quite some time to construct. I am not 100% certain that it is a must have, but time will tell.
A radial set-up will get around the problem I had with the magnets creating eddy currents in the rotor bearing block
Best regards
Peter
Hi Peter,
Nice work on that. I want to build one of those too. I plan on arranging my coils radially around a drum type rotor, rather than a disk rotor. Thats the only change I intend to make. Where did you get that variable cap? Let us know how it performs!
-Woody
I would like to introduce my new energiser. It is based on JB’s original machine FEG 1984, sometimes erroneously called the ‘Watson Machine’.
Specification:
Motor: MFA 800 12VDC Permanent magnet motor. Efficiency 58%
Shaft: Steel diameter 12mm
Bearings: ID 12mm OD 28mm Thk. 8mm open. Lubricated with baby oil.
Flywheel: Plastic wheel with two aluminium plates for extra mass.
Rotor: Aluminium, diameter140mm with 6 neodymium N42 magnets diameter 20mm x 10mm thick on a 100mm-pitch diameter.
Coils: 6 air coils at 2000 turns of copper magnet wire 0.40mm (AWG #26)
Rotating mass: 1.70kg
Speed: 4725RPM (Non pulsed & without coils)
Current: 2.04A (Non pulsed & without coils)
Rundown: 67s
Variable Cap. 200pF 5kV
I have tried to follow the design of JB’s original machine as I think this gives greater scope for modifications.
For the motor pulsing system I am using an op amp and opto reflective switch which I have tested driving a mosfet and a bipolar transistor.
For the energiser switching system I am planning to use the other half of the op amp and bipolar transistors.
The 6 coils in series produce a nice sine wave with a peak of around 220V. With the limited capacitors in my spares box I am getting voltages off the scopes display.
With this set-up the motor pulls around 19A on start-up. So I have added a two position switch with a resistor so that on start-up the motor pulls 8A non pulsed the second switch position then gives a pulsed full current.
This is the part of the circuit that I am happy about, I need to do further tests with the energiser switch.
If anyone has got a working circuit for the energiser switch please feel free to chip in.
For the future I have started making a widow motor to replace the permanent magnet motor.
Best regards
PeterTags: None
