Bedini 1984, 2017 style.
  • Faraday88
    OK, you are showing 8 strands with 2 strands in parallel on each coil, and 4 coils in series, is that correct...?
    And if so, you should make the 2 strand coils hooked up as series connected strands as well as connecting the individual coils in series... and then you need to put that output into a cap pulser, and or do the Konehead Ring the Ring trick to boost the genny energy collection into the cap pulser.......
    Hi RS,
    Could please elaborate on the 'konehead ring trick' I guess it has something to do with the coil shorting methods..
    Thank you in advance.
  • RS_
    Deuis,
    Great Setup, Great Experiments, Good Job.......
  • Yaro1776
    Originally posted by Deuis View Post
    I've been testing my SG with various magnet combinations to see how spacing effects performance.
    12V primary. Same trigger resistance. 26" wheel.
    6 magnets, 77hz, 210V peaks, .7A primary per coil.
    18 magnets, 222hz, 212V peaks, 2.4A primary per coil.
    36 magnets, 299hz, 216V peaks, 3.1A primary per coil.
    I thought that the tight magnet spacings would effect the peak V but this hasn't been the case.
    It does seem to have an effect to the top speed of the wheel however.
    The 36 magnet wheel running 299hz was pushing a 12V x 100ah battery to 13.2 fairly quickly.
    [ATTACH=CONFIG]7011[/ATTACH]
    Hey John,
    Looks like things are getting very interesting in this experimentation - love the set-up!
    Keep up the good work and thanks for sharing...
  • Deuis
  • John_Koorn
    Wow! that is cool. Although I'm having trouble seeing all of the images, aside from the 15 thumbnails. I can only see a full sized version of the first image.
  • Deuis
    https://www.sciencedirect.com/scienc...04885318311090
  • John_Koorn
    @RS and others It was my response for the Truth seekers not for hooligans!!!
    Faraday, can you please stop detracting this thread. From what I've read you haven't added any valuable discussion to the research Deuis is doing.
    Unless you can add something meaningful to the thread I'm going to have you banned. There will be no further warnings.
  • Deuis
    Yes its an 8 Strand coil with pairs of strands in parallel.
    These pairs are in series.
    Early days yet, but yes thats the plan.
    Heres a chart of this coil in the 3 different combinations.
  • RS_
  • Deuis
    Schematic was wrong.
    Its dual coils in series.
  • RS_
    Deuis,
    This is a series adding coil strands, what your Sch show's, is not series adding..... All though you may have your coil hooked up like this, and only the Sch is wrong.....
  • Faraday88
    Good try ..but not good enough!!!
  • Deuis
    Shoo fly, don't bother me.
  • Faraday88
    Thanks RS,
    This 23AWG Generator coil is a mutilstranded twisted coil in the below configuration.
    All testing was done with this coil in different configurations.
    Core pointed Vertically over the North Magnet
    [ATTACH=CONFIG]6984[/ATTACH]
  • Deuis
    Thanks RS,
