Bedini RPX Sideband Generators
This is off-topic...is it possible to overcharge either the Velleman Generator or the 12-volt Talent Cell?
Originally posted by Teslad View PostThanks Aaron. That answered my questions. The PCB idea sounds interesting. I never noticed how cheap PCB engravers have become. I am also guessing that you would use a single sided board is this correct. Lastly, do you happen to have a PIC of such a board I would love to just have a look. Thanks for you time and help.
The bottom side would be to channel the center of the spiral to the other side and then a trace up to a corner to pop out the top near the outside winding trace.
Originally posted by Teslad View PostHi Aaron, I would like to ask you a few questions about the coil you made in the "How to Setup the RPX" Video.
Q1
What size was the wire you used to make the coil it looked about 18 AWG? Also, you mentioned that John recommended a heavier gauge then what was used in the video. What was John's recommendation for the lower gauge?
Q2
Any advantages to a lower gauge wire considering the output wattage?
Q3
Why don't you recommend using the Tesla Bifilar? The video's I have watched seem to indicate the bifilar is more efficient.
Thank you for your time.
1 - This is 5kv insulated wire and works fine. Even with 1 foot thinner wired alligator clips and using an ohm meter, the entire thing is under 1 ohm. I do not believe thicker wire is needed. A 2 oz per square foot copper pcb with a spiral of 40 turns, 6 inches in diameter with 1mm thick traces (1mm thick space between traces) works fine as well and I can verify with the spectrum analyzer that it broadcasts everything just fine.
2 - I don't believe there is any. I should edit the video or at least check that I'm relaying what John mentioned, but again, I see no benefit.
3 - I haven't tried the bifilar method - all of John's were done with a single winding and that is what he recommended to me.
I hope that helps.
Q1
Q2
Q3
Thanks.
I was hoping that would work without messing up the RPX concept.
And yes, longer Resonance is my goal.
Originally posted by jmkwisc View PostI would like to experiment with a sweep that is cycles slower than the standard one so Hz would hold for a longer duration.
Would changing 0.1 speed to 0.01 slow it down or do I change another setting like Step from 100 to 10 on the HPG1?
That is really slow.
0.1 will cycle through the ranage (if using 100hz to 150khz) in about 7-8 seconds
0.05 will cycle in about 14-16 seconds
and so on...
If your desire is to get longer resonance at each frequency, then you have the right idea.
You could also narrow the sweep range and then you will hit each frequency more often in the same time by leaving the 0.1 speed so different ways to do it.
Originally posted by Oliver01 View PostHello Aaron
Just to say my rpx finally arrived, very excited to test it out now.
A previous question of mine seems not to have made it here. What is the reason you guys chose the low power output vs the 10+ watt power of John's machine that you demo in one of your videos?
I understand it may not be necessary but would be nice to understand the thinking?
Oliver
We're sure it will meet your expectations!
The 10 watt unit is too hot.
The small power units are strong enough.
Hello Aaron
Oliver
Rpx amplifier
Hi Aaron
What was the reason for choosing the present low power output vs john's 10+ watt model?
Oliver
Originally posted by Aaron Murakami View PostThe RPX units are already discounted - the retail is $425 and the reintroductory price is $385. The RPX book & video is not published by us so we cannot discount those products - we're required to sell them at the same price the publisher does.
You can email (help at emediapress dot com) for details. We can offer a deeper discount for bulk purchases of the RPX units.
Originally posted by erweii want to buy one RPX SIDEBAND GENERATOR ,one RPX combo and one Bedini RPX book & video ,could you give me a discount?and how could i send the paypal payment?
Originally posted by erweihi Aaron
i want to buy the RPX COMBINATION PACKAGES and bedini rpx book and video,the bedini rpx book and video is still free ?
The Bedini RPX book & video were never free - they're available here: http://bedinirpxbook.com
Months ago, we offered a free digital downloadable book or video from http://emediapress.com but those are different from the Bedini RPX book and video. The book/video package is a physical book/dvd and not a digital download.
Originally posted by jmkwisc View PostI deleted my question as I thought there was an issue but, NOPE...all is good
